Local Time 00:51 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DM timing microsecond?
robarino
Posted: 12:59pm 15 Mar 2012
I was wondering if any of you had used the auidio pulse as a counter. I am using the duinomite mega and I need to count with an accuracy of 10 microseconds. I can send a sound out at a frequency of 100 kHz from the audio jack. The question is how do I count the number of cycles in MMBASIC?
Thanks!
RobEdited by robarino 2012-03-17
Posted: 07:49pm 15 Mar 2012
Hi Rob,
I answered this in your email so this is more for someone else in the forum who might have the same question. It assumes that the sound output is connected to pin 13:
SOUND 100000, 3600000 ' 100KHz for a long time (1 hour)
SETPIN 13,5 ' set pin 13 as a counting input
PRINT PIN(13) ' get the count
PRINT PIN(13) ' count should have incremented
etc.
Posted: 01:31am 16 Mar 2012
I did this for an ultrasonic range detector.
58 uS delay equals 1 cm so a sound frequency of 17241 Hz was used.
Every 100mS, the program sends a start pulse out pin 15 then waits for the return pulse.
The sound output is connected to pin 11 which does the timing.
settick 100, mainloop
waitloop:
if cnt=0 then goto waitloop
if cnt <650 then print cnt*10
cnt=0
goto waitloop
end
mainloop:
cnt=0
sound 17241, 20000
setpin 15, 8
pin(15)=0
pulse 15, 0.02
pause 0.03
setpin 15, 6, begincount
ireturn
begincount:
setpin 15, 7, endcount
setpin 11, 5
ireturn
endcount:
cnt=pin(11)
sound 17241, 0
setpin 15, 2
ireturn
Posted: 01:55am 16 Mar 2012
Thanks!
Rob
Hi Rob,
Using Geoff's example on the DuinoMite you will need to use Pins 5,6 or 7 as the count input as he has quote Maximite Pin No.s so where he quote pin 13 you need to replace it with one of the others as here
SETPIN 5,5 ' set pin 13 as a counting input
PRINT PIN(5) ' get the count
PRINT PIN(5) ' count should have incremented
You will also need to use line numbers,
Hmm, On second thoughts, Maybe all of the above depends on which firmware you are using... If DM firmware (olimex) then what I said above is correct, if using Geoffs 12 pin MM firmware then what Geoff said is correct (I assume pins 10,11,12,13 are the count inputs on Geoff's DM version of MM 3.x)..
Now, depending on exactly what you mean to do 10us is very fast... each basic instruction, I believe, takes 30uS to process so doing something with 10uS accuracy is going to difficult come impossible.
robarino
Posted: 07:07am 16 Mar 2012
WOW Thanks for all that!
Geoff the initial code that you wrote was exactly what I was doing. Now I am sure that is right...I think my confusion is the pin setup on the duinomite mega rev c. I have plugged in the grounf from the headphone jack into the ground on my board. I then tried to plug in the signal to lots of different ports and get nothing.
I am using this document and it says pin A4, A5 and D10 with corresponding pin names 13,11,9
So I write this connected to A4:
[code]
etc.
[/code]
@Tassyjim I don't need the timing for processes per se. I am measuring mechanical vibrations and I need a timer that could count by 10 microseconds. If I sample at 2 kHz I can live with a timer of 500 microseconds with +/- 9.99999 microsecond accuracy. To be honest I am shocked at how fast the sd card writes. It completely blows NETMF out of the water for sd write times and array filling.
I have run this code numbered and I get 1's from every port. In addtion MMBASIC will only allow setpin 12,5 and setpin 13,5.
Frankly it there is a little confusion on my part concerning the olimex hardware documentation...pins layout etc.
In this respect I would like to contribute though by taking the Arduino examples and rewriting them in Basic for the beginners though. Those resources help a lot.
DUINER.com
paceman
Posted: 12:36pm 18 Mar 2012
Thanks!
Rob
Rob,
There's a page and a half discussion on using the Maximite for exactly this in the March issue of "Silicon Chip" (pp 68 Circuit Notebook section). It involves a small amount of external circuitry but apparently gives a resolution of 5 microseconds.
Greg
