Local Time 01:05 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PS2 keyboard chip, more inputs?
Posted: 04:09am 13 Mar 2012
Just thinking out loud. The 'mite has a PS2 keyboard interface. A PS2 keyboard has like 100 keys. Thats 100 digital inputs, accessible with the INKEY$ command.
Is there a PS2 encoding chip, that can take switch or digital inputs and send out PS2 serial data, for connection to a Maximite.
It would give us a lot of extra digital on/off inputs, say for monitoring, etc, and means we still have the 20 odd 'mite pins to control and sense analogue, duration, etc.
One application would be a custom built ( and compact ) keyboard, with say 12 keys, instead of a full sized keyboard.
jman
Posted: 04:37am 13 Mar 2012
Like this
KeyPad
We could rip this apart and see how's it is done.
I assume the keys will be in a matrix
Posted: 05:48am 13 Mar 2012
Yeah sort of. Thats a neat little keyboard, but I'm more after the chip itself. Chances are the chip in that keyboard is under a blob of black epoxy unfortunately.
djuqa
Posted: 06:04am 13 Mar 2012
The original PC / AT /PS2 Keyboards were a simple matrix of keys & an Intel single-chip 8048 microcontroller. Nothing complex, the same could be done today using a simple Pic or similar micro-controller.
Edited by djuqa 2012-03-14
VK4MU MicroController Units
jman
Posted: 07:54am 13 Mar 2012
Just a thought we can use 1 analogue pin and a resistor ladder
Hneo2au
Posted: 08:54am 13 Mar 2012
Do a search for Ultimarc I-pac2 keyboard encoders.
They have a interface that emulates a keyboard from contact inputs.
A bit pricey though.
darthmite
Posted: 12:43pm 13 Mar 2012
Hi ,
long time ago (2009)i do a little project to read a USB/PS2 keyboard and send the
ASCII code as serial.
It just use a simple little Pic 16F688
The header file is prepared for 3 different keyboard layout , actually it
was just the German layout active , The US and FR layout are just a copy/paste
from the German one. You then just have to put the right code under this sections
to be able to use the US and FR layout.
Read the comments at start from the *.c file to know how to use the other layout.
Here the Schematic :
2012-03-13_224251_16F688_USB_Keyboard_Decoder_schematic.zip
and the source code made with CCS C PIC compiler.
2012-03-13_223718_Keyboard_16F688.zip
I no more have this circuit at home for made the US and FR or other layout.
I hope it can help
This circuit is so small that you can directly integrate it into a KB and send
the serial data tough the PS2 cable
Cheer.
Edited by darthmite 2012-03-15
vasi
Posted: 08:34pm 13 Mar 2012
Tests must be done to see how fast you can switch without loosing the count. How fast is that chip? Is doing a multiplexing?
Elvish name: Mablung Miriel
Beyound Arduino Lang
BobD
Posted: 09:11pm 13 Mar 2012
Another approach if you want more signal lines is to use the Remote 8-bit I/O expander for I2C bus - PCF8574. You can put 8 of these on an I2C bus and each has 8 "quasi-directional I/O ports". To run them you also need a digital input for the chip(s) to notify the processor there is inbound data.
2012-03-14_070625_PCF8574_data_sheet.pdf
There is also version called PCF8574A which can have 16 chips on the bus but it seems to use an extra address bit which, I think, will prevent its use with the MM.
paceman
Posted: 02:59am 14 Mar 2012
How about these,
MC74HC595A
8-Bit Serial-Input/Serial or
Parallel-Output Shift
Register with Latched
3-State Outputs
http://www.nxp.com/documents/data_sheet/74HC_HCT595.pdf
They use serial SPI out, not I2C but they're also cascadable. No input, just output but if that's what you want. Sparkfun even have a tutorial on them:
http://www.sparkfun.com/products/10680
GregEdited by paceman 2012-03-15
Posted: 07:21am 14 Mar 2012
  Gizmo said   Just thinking out loud. The 'mite has a PS2 keyboard interface. A PS2 keyboard has like 100 keys. Thats 100 digital inputs, accessible with the INKEY$ command.
This is something I did many years ago.
I started with an old keyboard that had crook keys, put the hacksaw through the board and kept the electronics.
The keys are multiplexed so you need switches or relays to get the inputs.
I am currently doing things in reverse.
I have a USB keyboard being fed from a maximite (the electronics are bigger than the maximite). This keyboard is in a laptop and the key press is needed to wake a program up.
The maximite operates a reed relay which operates the 'space' key on the laptop.
Working out which wires go to which key is the hard part.
vasi
Posted: 09:40am 14 Mar 2012
Hi Jim,
I used an 18F2550 (my FreeJALduino board) with Jalv2 language and USB keyboard library to simulate a second USB keyboard, actually firing a train of [Space key] codes, needed in a game which I played with my daughter. It had also a switch (an input to microcontroller), for On/Off the output. This helped me to protect my keyboard .
It is very easy to setup and program if you are accustomed with PIC 18F programming. The Jal language is very easy and intuitive if you programmed before in Pascal or Verilog...
It would be great if Maximite could allow the software upload form a serial interface (using also FTDI) and letting USB setup for the users (or different versions of the firmware). But you can't do everything from an interpreter. Sooner or later you must go to real programming (mikroElektronika have mikroBasic for PIC32). Anyway, PIC32 for just that is definitely an overkill.Edited by vasi 2012-03-15
darthmite
Posted: 09:57am 14 Mar 2012
  vasi said   Tests must be done to see how fast you can switch without loosing the count. How fast is that chip? Is doing a multiplexing?
The 16F688 is 8Mhz , the serial is set to 9600 baud , when i have use it i don't
have loose any chars i pressed on the KB.
You will see in the source that the PIC only wait and translate the keyboard scan-code.
I don't have use interrupt , it's a pure bit banging system because every KB don't
send the bits at the same speed.
And about how fast it was , you can consider that it was exactly the speed of the KB
Cheers.
vasi
Posted: 10:33am 14 Mar 2012
Cheers.
Hi, I mean the keyboard chip Glenn pointed.
