Local Time 01:05 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Reading/Writing 8-bit files
rodent59
Posted: 12:23pm 06 Mar 2012
This may well be generally known, but just in case it's not...
For MMBasic3.1
While all INPUT and PRINT commands deal with ASCII (7-bit) characters, they can handle 'whole' 8-bit bytes as follows:
Open any non-text file (say a .pdf or .jpg for example) and read a single byte:
a$=input$(1,#1)
print ASC(a$) 'returns the 8 bit result (0 to 255) or
print HEX$(ASC(a$)) 'returns the hex code for the byte.
When writing to a file:
print #2,CHR$(250); 'will write a single byte to file with decimal code 250 or
print #2,CHR$(&HE8); 'will write a single byte to file with hex code E8.
Might be useful if reading/writing non-text files sequentially.
Apologies if this is old news!
Posted: 06:12am 08 Mar 2012
Good point rodent.
In fact ver 2.1 could not do this and it was only in ver 2.3 (I think) that I rewrote the string handling to fix it. Now all string handling is 8 bit "clean". So you can (for example) do a$ = chr$0) and so on.
Also, USB is 8 bit clean, so you can print a null character to the host PC by doing PRINT chr$(0)
GeoffEdited by Geoffg 2012-03-09
PeterR
Posted: 09:49am 08 Mar 2012
Thanks Rodent, I been trying to work out how to send 8 bit non text data.
Geoff, can you use this on a serial port?
Eg.
open "com1:4800" as #1
print #1,chr$(0)
I seem to be having issues.
Peter
Peter
Posted: 10:35pm 08 Mar 2012
  PeterR said  Geoff, can you use this on a serial port?
Eg.
print #1,chr$(0)
Yes, that works fine. I have an application that drives a serial LCD using codes like that.
aargee
Posted: 04:10am 09 Mar 2012
That's why my cursory go at serial GLCD driving failed! Thanks for the thread everyone.
- Rob
