Local Time 00:51 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Bit Manipulation
jman
Posted: 11:28pm 03 Mar 2012
Hi
I have a 16 bit register that requires the data to be sent as
2 8 bit bytes. The value that needs to be sent is 8 bits and needs to be
shifted to the right by 6
For example &B11000011 needs to be represented as
HighByte = &B00110000
LowByte = &B11000000
To get the correct 16 bit number I can times the number by 64
so &B11000011 x &B1000000 = &B0011000011000000
So now we it shifted to the left by 6 places
I Can get the HighByte by &B11000011 / &B100 = &B00110000
Now to get the LowByte = STUCK
Any Help would be greatly appreciated
Posted: 12:11am 04 Mar 2012
Hi John,
The AND operator actually does a bitwise and operation. So, to get the low byte you can do:
&B0011000011000000 AND &B11111111
and you should get &B11000000 as the result.
If you are shifting right you should use the integer divide operator (\) ie, a back slash. This will discard any fractional value as a result of the divide. So, to get the high byte you can do:
&B0011000011000000 \ 256
and you should get &B00110000 as the result.
jman
Posted: 12:43am 04 Mar 2012
Hi Geoff
Thanks for the explanation. Works perfectly
I knew the clever folk would have a simple way to it :)
crackerjack
Posted: 03:16am 04 Mar 2012
Jman, I posted some bitwise routines here: http://www.thebackshed.com/forum/forum_posts.asp?TID=4218
I hope to update them to use Sub's but may wait for 3.2
Cheers.
Posted: 09:00am 04 Mar 2012
  crackerjack said  I hope to update them to use Sub's but may wait for 3.2
Yes, definable functions would make that a dream.
paceman
Posted: 10:23am 04 Mar 2012
They seem like a very good candidate for the MM library. Greg
