Local Time 00:25 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic I2C RTC Addressing Problem?
DuinoMiteMegaAn
Posted: 11:16pm 29 Feb 2012
The problem is the DS3231M uses 7 bit addressing as opposed to 10 bit addressing per spec. sheet
Using the DS3231M is rejected by MMBasic 3.1 because the device addressing is above 127?
Is it possible to allow this precision low cost RTC device using 7 bit addressing in MMBasic?
The following Maxim-IC battery backup compatible I2C RTC devices have the following slave addressing:
DS1307 DEC 104 0x68 <------- +- 20 ppm <--- 8 pin dip <---- works in MMbasic
DS3231 DEC 104 0x68 <------- +- 2 ppm <-Precision RTC 16 soic <-- works in MMBasic
DS3231M DEC 208 0xD0 <------ +- 5 ppm <- Automotive precision RTC 8 soic(low cost)
Note: The addressing range of the DS1307 and DS3231 is less than 127 and they all work perfect in MMBasic.
BobD
Posted: 11:41pm 29 Feb 2012
Andy
The data sheet may be in error. If you look at page 16 it writes that the address is 0xD0. On the same page in fig 8 it shows the address as 0x68. Fig 9 also shows the address as 0x68.
Bob
Are you considering using the DS3231M? If so, have you seen the Errata Sheet out on it? http://pdfserv.maxim-ic.com/en/errata/DS3231MA1.pdf
Just noticed that 0x68 shifted 1 bit left is 0xD0. Methinks whoever wrote the sheet got his bits muddled.Edited by BobD 2012-03-02
DuinoMiteMegaAn
Posted: 12:42am 01 Mar 2012
Maxim_IC DS3231M 19-5312: Rev 3: 12/11 Document PDF <------<<<<<
Page 16 Under i2C serial Port operation quote "The device slave address byte is D0h" <---- This is definately wrong.
Page 16 Figure 8 is MSB 1101000x = 0x68 hex or 104 DEC
Page 17 Figure 9 is MSB 1101000x = 0x68 hex or 104 DEC
All three I2C devices should have the same device address which they do.
The tech pub writer needs to review his work!
Thanks BoB
BTW ... I just tested this new SOIC8 DS3231M and so far it works fine.
Now if some enterprising person would make a RTC module with this chip for the
MaxiMite then there won't be any more large RTC errors due to temperature variations. I can't live with 2.628 minutes per year but not the 10-20 minutes on the DS1307. Edited by DuinoMiteMegaAn 2012-03-02
CircuitGizmos
Posted: 01:13am 01 Mar 2012
0xD0 = 11010000
0x68 = 01101000
Just a shift. Of you do or don't count the r/w bit 0 as part of the address you will see how 0xD0 and 0x68 are related.
DuinoMiteMegaAn
Posted: 03:07am 01 Mar 2012
CGMMStick1 + precision I2C rtc DS3231M = data logger
