Local Time 00:26 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : out of general memory
BobDevries
Posted: 06:20am 10 Feb 2012
Hi all,
I'm trying to convert a Tandy Colour Computer programme for use with the Maximite, but I'm running into memory problems.
The line that barfs is:
130 DIM VM$(110,1),A$(80),R1$(17),R3$(34),R4$(23),R5$(24),R6$(13)
The programme is called VARMAP.BAS. Those of you from Coco backgrounds may remember it.
It prints all the variables used in your programme and shows the line numbers where they are found.
Now, a Colour computer has just ~24K memory free when no programme is loaded, so I can't understand why the maximite can't handle this when it's got ~37K with the programme loaded.
Anyone got any clues?
Bob Devries
Dalby, QLD, Australia
djuqa
Posted: 06:34am 10 Feb 2012
maybe those dim statements needing re-thinking?
they will use 80k of memory if each string element is reserved 256bytes
Maybe Use a data file to store the accumulated values
Edited by djuqa 2012-02-11
VK4MU MicroController Units
BobDevries
Posted: 07:46am 10 Feb 2012
But.....
The programme works in a Tandy computer with less than 32K free RAM!
Why not on the Maximite?
Bob Devries
djuqa
Posted: 07:58am 10 Feb 2012
Different size string Variable at a guess.
With the speed available on MM parsing thru the BASIC File and printing the accumulated data at the end of program maybe option
MM_Wombat
Posted: 08:02am 11 Feb 2012
I had the same problem when I wrote Maxifont. Geoff G wrote
Each element in a number array uses 4 bytes. So, dim plot(4,100,30) would use up about 47KB which is more than the space available for arrays (which from memory is about 37KB). Moving to option base 1 would reduce your memory consumption a bit but still not enough to fit in.
A floating point number can be used to hold quite a large integer which you could pull apart into individual bits. For example you should be able to store 16 bits in each floating point number but manipulating the bits in BASIC would be tedious (you would use AND and OR which do bitwise manipulation).
I would suggest using strings. If you declared an array of strings like: dim str$(64) then each string could be one row (or line). Each element in a string array uses 256 bytes so by doing that you would use only 16KB of general memory. If you used the convention of X as a pixel and space as no pixel writing out the font would be as simple as looping through the array doing PRINT #1, str$(loopcntr)
Hope this helps
mm_wombat
Maximite, ColourMaximite, MM+
Olimex
Posted: 10:25am 11 Feb 2012
  BobDevries said   But.....
probably the Tandy computer BASIC use dynamic string sizes.
it's always trade off between speed and memory.
if you use fixed size 256 bytes per string you waste memory but increase the speed, if you use dynamic string sizes you have to move lot of memory blocks each time you access strings so this will decrease the memory usage but lower the speed
mookster1
Posted: 08:55pm 12 Feb 2012
The Maximite deals with 32-bit numbers only in arrays so I'd probably say that was the case. As the Tandy was 8 or 16-bits (can't remember which) it probably used that size for each cell in the array, hence why it works on the Tandy and not on the Maximite.
Capacitance is futile - roll on 2012!
