Local Time 00:25 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM print problem
palcal
Posted: 08:13am 08 Feb 2012
Me again pestering all you helpful folk. I have a problem with an extra space being put in a print statement.
In the code:-
a=6:b=10
print a":"b
the result is 6: 10 when it should read 6:10
why does the extra space come in after the colon.
Paul.
djuqa
Posted: 08:26am 08 Feb 2012
Working exactly as per the language specifications
VK4MU MicroController Units
Posted: 08:30am 08 Feb 2012
Most (all?) Basics are defined to do that. You want a formatted print.
Have a look at things like FORMAT$()
ajkw
Posted: 10:06am 08 Feb 2012
palcal,
another idea is to print the numbers as strings.
ie
print str$(6);str$(10)
or
a=6:b=10
print str$(a)+":"+str$(b)
Cheers,
Anthony.Edited by ajkw 2012-02-09
crackerjack
Posted: 10:59am 08 Feb 2012
...or for not-terribly-realistic solution, try the new PRINT @ syntax, e.g.
[code]
a=6:b=10
cls:print @(100,100) a:print @(115,100) b:pixel(115,103)=1:pixel(115,106)=1
[/code]
...of course it is hardly a real solution, just making a point that there are many ways to achieve an outcome in MMBasic.
Keep havin' fun! (and stick with what ajkw said).Edited by crackerjack 2012-02-09
shoebuckle
Posted: 10:35pm 11 Feb 2012
Try
a=6
b=10
Print Format$(a)":"Format$(b)
Prints "6:10" without a leading blank.
Cheers,
Hugh
mookster1
Posted: 08:51pm 12 Feb 2012
I seem to be having probelms with PRINT @. When I told it to put an X in the middle of the screen (240,216) it put the X significantly to the right of that (the Y coord was OK though.) X=0 makes the X appear about 10 X's (can't remember the exact pixels) out from the left edge. Probably not the right place to put this, but has anyone else had this problem? BTW I'm using MMBasic 3.1
Capacitance is futile - roll on 2012!
