Local Time 00:12 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : more on the DS3231 Real Time Clock
BobD
Posted: 05:41am 08 Feb 2012
Back in November and December 2011 DuinoMiteMegaAndy ran a thread on his Precsion Real Time Clock project. Since then I have bought a Chronodot RTC and got it running using some code fragments from Andy's project. I was much less ambitious than Andy so all I do so far is read and set the RTC and use it to set the Maximite clock.
As well as keeping time the DS3231 also measures temperature. Today I thought I would have a go at reading the teperature. It turned out to be easier than I thought. Here is the code I used to read it. It is MMBasic V3.1
sub getRTC_Temperature
RTCregister=&H11 ' first Temperature register
DataLength=2
I2Caddr = &h68 ' DS3231 I2C address 0x68
I2CEN 100,100 ' Enable I2C at speed 100Khz 100ms timeout
I2CRCV I2Caddr, 0, DataLength, RTCdata(RTCregister), 1, RTCregister
' insert error checking here if required, read var MM.I2C
I2CDIS
if RTCdata(RTCregister) < &H80 then
' temperature is not negative
' bits 6 & 7 in register &H12 are fractional degrees where
' &H40 is 0.25 degrees, &H80 is 0.5 degrees and &HC0 is 0.75 degrees
Temperature = RTCdata(RTCregister) + (RTCdata(RTCregister + 1) / 256)
else
' for our friends in the cool countries, if the temperature is negative then
' the first temperature register has a negative twos complement integer
temperature = -(((RTCdata(RTCregister) xor &HFF) + 1) + (RTCdata(RTCregister +1) / 256))
endif
end sub
DIM RTCdata(19)
getRTC_Temperature
? Temperature
The code can handle a temperature range of +127.75 to -127.75. If the MM gets anywhere near those values I don't think we'll care what temperature it is. One point I wasn't sure of was how to compute a negative temperature. The DS3231 datasheet didn't help much.
The question was should I convert the first temperature register to a negative value and then add the fraction register or should I add the absolute values of both registers and then convert to negative. My code does the second method. Anyone else know how it should be?
I also had trouble with the I2CRCV command. I couldn't be sure from the MMBasic manual and Andy's code exactly how to read a DS3231 register in isolation. If anyone else had that trouble I hope that my code helps a bit.
Next is to see how accurate the the DS3231 is and if necessary adjust the Aging Offset Register (10h) to make it more accurate. Anyone had a go at that yet?
Bob
