Local Time 00:13 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : EEPROM 24xx
ztoti
Posted: 09:18pm 06 Feb 2012
Hi guys
Anybady has sample with read/write to 24c64? (Any 24xx)?
I did try many different way to do this' but with no sucess.
Please helpEdited by ztoti 2012-02-08
Bill.b
Posted: 09:47pm 06 Feb 2012
Hi Ztoti
More information would help.
what address you are using
is your speed setting 400k
are you using I2C
schematic.
sample of your code.
regards Bill
ztoti
Posted: 10:10pm 06 Feb 2012
Hi Bill,
The sample is below:
Complete=0
I2cen 100,1000,eprom
I2csend &h50,0,2,0,10 ' write 10 at memory address 0. Pin 1,2,3,4,7=GND
Do while complete<>1
Complete=0
If mm.i2c<>0 then
Print "error during sending";mm.i2c
Else
Print "send is complete"
Endif
,----- read location 0 --------------
I2crcv &h50,0,1,0,n
Pause 1000
Print n
End
'------ interrupt----------
I2cdis
Eprom:
Complete=1
Ireturn
Bill.b
Posted: 12:03am 07 Feb 2012
I see you are using 100khz timming.
what is the supply to the EEprom 3.3 of 5v
It is recomended that the timming is 400khz for
5v supply -
I2Cen 400,1000
BobD
Posted: 07:37am 07 Feb 2012
I2cdis
Eprom:
Complete=1
Ireturn
If your I2cdis is important and I think it is, then it is in the wrong place as it will never get executed. When the interrupt at the end of the transfer is completed then execution flow will jump to the label Eprom:.Edited by BobD 2012-02-08
boss
Posted: 04:08pm 08 Feb 2012
all kind of 24xxx eerom's need an extra time for write operation. You may found this in datasheet. In my case (AT24C32) time for complete "write op" is 10ms.
boss
Pause 10
I2cdis
If mm.i2c<>0 then
Else
Endif
boss
Posted: 04:26pm 08 Feb 2012
Hi ztoti,
here is an example:
Rem WRITE TO AT24C32
Dim RTCBUFF(4196)
I2CADDR=&H50 ' 24C32
K=&hAC
For J=&h0 To &hF
For I=&h0 To &hFF
I2CEN 100,100 'ENABLE I2C
I2CSEND I2CADDR, 0,3,J,I,k
I2CDIS
Pause 10
If MM.I2C <>0 Then Print "1=NAK 2=TIMEOUT"; MM.I2C,j,i:End:EndIf
'L=(j*256+I)
'Print "Byte ";L, " ";Chr$(13);
Next i: Next j
Print "ROM HAS BEEN WRITTEN with "; K
boss
ztoti
Posted: 07:33pm 08 Feb 2012
Thanks boss,
This is great examples but did you try to read from 24XX?
That is my bigest problem, how to read from any location.
If you have a solution please share it.
Thank you
BobD
Posted: 12:25am 09 Feb 2012
You could try this to read from any location
I2CRCV I2Caddr, 0, DataLength, EEPROMdata(HI_addr * 256 + LO_addr), 1, HI_addr, LO_addr
where HI_addr ranges from 0x00 to 0x1F and LO_addr ranges from 0x00 to 0xFF to select the EEPROM address you wish to start reading from. If DataLength=1 then the EEPROMdata var does not need to be an array. The array index does not need to be the same as the address but it does make it less confusing.
This info from the datasheet. I don't (yet) have one of these devices.Edited by BobD 2012-02-10
boss
Posted: 05:00am 09 Feb 2012
Hi ztoti,
here is the exeample -enjoy it
Rem READ From AT24C32
Dim RTCBUFF(4196)
K=&hAC
Pause 10
For I=0 To 4095
RTCBUFF(I)=&H0
Next I
For J=&H0 To &HF
For I=&h0 To &hFF
L=(j*256+I)
I2CSEND I2CADDR, 0,2,J,I
I2CRCV I2CADDR, 0,1,RTCBUFF(L)
' Print "Read Byte "',L;Chr$(13);
I2CDIS
Next I: Next J
For I=0 To 4095 Step 8
Print "Byte ";I;" ||";Hex$(RTCBUFF(I));"|";
Print Hex$(RTCBUFF(I+1));"|";Hex$(RTCBUFF(I+2));"|";
Print Hex$(RTCBUFF(I+3));"|";Hex$(RTCBUFF(I+4));"|";Hex$(RTCBUFF(I +5));"|";
Print Hex$(RTCBUFF(I+6));"|";Hex$(RTCBUFF(I+7));"||";(I+7)
Next I
regards
boss
