Local Time 00:25 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMIDE 2.0g - fixes a couple of bugs
CircuitGizmos
Posted: 06:27pm 06 Feb 2012
MMIDE can be downloaded here: MMIDE2.0g
Next release will need to be a rewrite to support edit mode.
VK6MRG
Posted: 12:28pm 07 Feb 2012
Love your work!
Could PIN 0 be added to the Blink LED Applet drop down box?
I know you have the CGMMSTICK1 LED button, just a thought.
And just a very minor bug on the MMBasic page.
CLEAR SCROLL BACK button is fixed in the same place no matter what the screen size is.
When i fist start the MMIDE program all is well. But if I maximise the window the CLEAR SCROLL BACK button stays in the same place and the other buttons end up on top of it.
Only a cosmetic thing and nothing more.
Thank you for your hard work.
Matthew
CircuitGizmos
Posted: 05:34pm 07 Feb 2012
Thanks, Matthew! I'll fix the button for the next release.
OK - I'll blink LED 0, too.
VK6MRG
Posted: 04:55am 08 Feb 2012
Thank you very much.
Awesome work.
paceman
Posted: 10:15am 13 Feb 2012
  CircuitGizmos said   MMIDE can be downloaded here: MMIDE2.0g
Hi Gizmo,
I might have found a minor bug in MMIDE2.0g this afternoon when I posted about the "OPEN" command - on the other hand it may be as it should be! I copied back the program running (i.e. was running) in the Maximite using the "Save current program in MM to PC" button on the "MMBasic" tab. When I looked at the file on the PC (using Notepad) the program was all one long list, not line formatted with CR/LF's.
When I tried again using the "Save from MM drive" button on the "Utility" tab, i.e. reading the file saved on the SD drive, it came across properly formatted. Am I missing something here?
Greg
CircuitGizmos
Posted: 02:00pm 13 Feb 2012
"not line formatted with CR/LF's."
The LFs are there (should be) but the CR are not. The Maximite does not include CR at the end of the lines, so the captured listing would not include the CR.
paceman
Posted: 11:14am 14 Feb 2012
  CircuitGizmos said   "not line formatted with CR/LF's."
Hi Gizmo,
Can't see any LF's when I read the file with Notepad but when I pasted it back into here for you to see it magically was properly formatted. Seems Notepad doesn't show the control characters?
Greg
