Local Time 23:46 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM basic
palcal
Posted: 06:27am 07 Jan 2012
Does anyone know if MM basic supports nested For Next Loops, I have tried to use one and keep getting error message 'for without next'.
Also have written a program using Labels instead of line nos. and when using GOSUB get an error message 'cant find label'.
Paul.
seco61
Posted: 06:32am 07 Jan 2012
Hi Paul.
Yes, MMBasic does support nested For Next. Please post a sample of your code that is getting the error and we can check for syntax issues.
As regards the Labels with MMBasic 3.0 - it should work but I know there are some minor bugs in the initial release and Geoff will be releasing 3.0A in the near future to resolve those issues. I am not certain if your problem is one of the bugs - best to go to Geoff's web site and check out the "known bugs" section.
  palcal said   Does anyone know if MM basic supports nested For Next Loops, I have tried to use one and keep getting error message 'for without next'.
Paul.
Gerard (vk3cg/vk3grs)
crackerjack
Posted: 07:01am 07 Jan 2012
Make sure you identify which NEXT relates to which FOR and that they don't overlap; e.g.:
Good ===>
FOR i = 1 to 10
FOR j = 1 to 10
? i * j
NEXT j
NEXT i
Bad ==>
FOR i = 1 to 10
FOR j = 1 to 10
? i * j
NEXT
NEXT
Worse! ==>
FOR i = 1 to 10
FOR j = 1 to 10
? i * j
NEXT i
NEXT j
Cheers....
