Local Time 00:26 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : HH10D humidity sensor
palcal
Posted: 07:01am 02 Jan 2012
Anyone know how to access the OFFSET and SENS values from the eprom of this device using the MM. I have done a few calculations with various values and don't think they are all that critical but it is nice to be accurate.
Paul.
Keith @
Posted: 07:27am 02 Jan 2012
Hi Paul
I don't have a direct answer but I suggest you have a look at the Sparkfun web page
http://www.sparkfun.com/products/10239
have a look at the forum info on the above page and the data sheet and the arduino article to see if they may help you.
KeithEdited by Keith @ 2012-01-03
The more we know, the more we know we don't know !
seco61
Posted: 11:20am 05 Jan 2012
Hi Paul.
The following code should read the data from the EEPROM (however I do not have one of these sensors so I am just working from the datasheet(s)).
It will then calculate the the offset and sensitivity values and use these in the following loop which will calculate and print the relative humidity every 5 seconds (assuming the FOUT terminal from the sensor is connected to pin 11 on the maximite, the SDA terminal is connected to pin 12 and the SCL terminal is connected to pin 13 - a pullup will be required on the SDA and SCL pins (2.2K - 4.7K) and a common ground between the maximite and the sensor):
100 DIM hcal(4)
110 I2CEN 100,500
120 I2CRCV &h51,0,4,hcal(0),1,10
130 I2CDIS
140 IF mm.i2c <> 0 THEN
150 PRINT "Error during EEPROM read - error code: ";mm.i2c
160 END
170 ENDIF
180 hsens = hcal(0) * 256 + hcal(1):PRINT "Sensitivity: ";hsens
190 hoffset = hcal(2) * 256 + hcal(3):PRINT "Offset: ";hoffset
200 SETPIN 11,3
210 DO
220 PAUSE 5000
230 humidity = (hoffset - PIN(11)) * hsens / 4096
240 PRINT "Humidity: ";humidity;"%"
250 LOOP
  palcal said   Anyone know how to access the OFFSET and SENS values from the eprom of this device using the MM. I have done a few calculations with various values and don't think they are all that critical but it is nice to be accurate.
Paul.
Edited by seco61 2012-01-07
Gerard (vk3cg/vk3grs)
palcal
Posted: 08:37am 18 Feb 2012
Been in Darwin fishing but now back to trying to work this out. Ran the program with the SDA and SCL connected to pins 12 and 13 but keep getting error 2. I increased the time in line 110 but still the same. The program did run through once but both the values were zero.
Thanks for the program, have you any ideas.
Paul.
BobD
Posted: 04:48pm 18 Feb 2012
Just a thought, see the quote below from the MM Basic Manual. seco61 said this earlier, do you have the resistors in place because the HH10D does not have them.
When enabled the I2C function will take control of the external I/O pins 12 and 13
and override SETPIN and PIN() commands for these pins. Pin 12 becomes the I2C data
line (SDA) and pin 13 the clock (SCL). Both of these pins should have external
pullup resistors installed (typical values are 10Kohms for 100KHz or 2Kohms for 400kHz)
Edited by BobD 2012-02-20
palcal
Posted: 09:16pm 18 Feb 2012
Thanks for that, I already had pull ups on these pins and disconnected them when I connected the HH10. Will reconnect and see what happens.
Paul.
palcal
Posted: 09:58pm 18 Feb 2012
Connected 10K pullup resistors to the 3.3V line and all works well.
Thanks to all who helped.
Paul.
palcal
Posted: 07:48am 19 Feb 2012
Well I thought all was OK, I have three of these sensors, the first one worked first up and I got the values from the EPROM. So I then connected the next one and I got the time out error and the same with the third one. I have altered the value of the pull up resistor, changed the time and frequency for I2CEN, all to no avail. Somehow I think the EPROM in the sensors is a bit suspect the sensors work fine but I just can't calibrate them.
Paul.
crackerjack
Posted: 10:03am 19 Feb 2012
Paul, how are you addressing three of theses devices on the same I2C bus. I don't know the device but you would obviously have to configure them somehow for unique addressing on a single bus, right?
EDIT: After rereading the thread I guess you are not using all three sensors at once, just trying to read the calibration data for each one at a time, so please ignore my ignorant post. Edited by crackerjack 2012-02-20
