Local Time 23:46 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : mini maximite
palcal
Posted: 04:09am 01 Jan 2012
Thanks for the help with my loading problem, now using MMIDE and have loaded the file OK. I have named the file "AUTORUN.BAS", my problem now is that on startup the program loads but does not auto execute, I have to type "RUN" to get it going.
Paul.
CircuitGizmos
Posted: 04:55pm 01 Jan 2012
Are you sure it doesn't execute? It may be done running before you open the USB port to the mini.
palcal
Posted: 08:26pm 01 Jan 2012
Did;nt think of that will investigate further'
Thanks Paul.
