Local Time 23:46 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : (DM) DuinoMite.com
donmck
Posted: 10:18pm 24 Dec 2011
DuinoMite.com
I just put together:
http://www.DuinoMite.com
which will hopefully give the DuinoMite an individual identity, as I feel the constant comparisons between the MaxiMite and the DuinoMite isn't achieving a great deal.
The DuinoMite Newsletter Subscription page is at:
http://www.dontronics-shop.com/mailing-list-dontronics-newsl etter.html
This will keep you up to date with DuinoMite Firmware and other News
Merry Christmas to all from the DuinoMite Team, and have a great 2012.
Cheers Don...
https://www.dontronics.com
djuqa
Posted: 02:32am 25 Dec 2011
Sounds good, the Duinomite Series are competent products that needs to be promoted as a separate but related product range.
Duinomite.com sounds a Great concept.
Open Source means adaptation & innovation not just cloning.
In 2012, my Maximite.com.au will cover the Maximite & MMBasic for the purists, and also the variants including my own version.
Duinomite, Maximite, UWB32 & the ?????Mite will mutate/develop into separate but related projects.
The world is big enough for ALL the PIC32 Based modules to co-exist, and be united against the common enemy! TTL Logic
Edited by djuqa 2011-12-26
VK4MU MicroController Units
swoodgate
Posted: 12:06am 27 Dec 2011
Hi Don
Is there a standardised location for firmware versions?
Currently there seem to be versions appearing in different topics on this forum but I am not sure they are approved software. It's also not obvious to me where to look on Duinomite.com for the latest official releases.
Thanks and best regards
Steve
djuqa
Posted: 12:30am 27 Dec 2011
If it is ok with Olimex, KSD, Dontronics, Geoff Graham et al I will publish links to all on my site
Bryan1
Posted: 01:43am 27 Dec 2011
Hi Steve,
Don hosts the latest releases on his site and here is the link . now also hosted there is the latest 'help' file too aswell as a heap of other goodies. By pressing the first link(folder with the arrow) it will take you back one step and such. All files can be located in sections and it is a very handy way to do it.
Regards Bryan
swoodgate
Posted: 06:37am 27 Dec 2011
Hi Bryan
Thanks for the link.
There are also firmware versions on topics in the forum.
For example the 1wire fixes published today.
But I suppose these are not official and will migrate to the release directory over time.
If I could suggest a direct link to "Firmware" from the front page of the site,
it would probably save people a lot of time.
Regards Steve
donmck
Posted: 08:35pm 27 Dec 2011
I am somewhere between a Tornado and two cyclones right now. (Back in Darwin).
DuinoMite.com was only set up a few days ago, so I have to edit 37 million links to make it all mesh in correctly.
Unfortunately Olimex point to a file with a file name. When the file name changes, the link no longer works, and every page that was ever written with that link in place, is no longer valid.
When I point to a file, I point to a directory. This means you have a copy of all firmware files, as long as the directory continues to exist.
And that is why there are several copies of the firmware. So you can blame me for that. I am the one that updates the files within 5ms of getting them, so if you follow mine, you will be pretty close to correct.
You can follow the new firmware by subscribing to the DuinoMite Mailing list.
I have just spent a little time on the main navigation links at DuinoMite.com
If there is a link, a file, or anything else that you find confusing at DuinoMite.com, please let me know and I will fix it.
Cheers Don...
Posted: 03:11pm 28 Dec 2011
I quite like links to a directory :)
However, generally it seems you can't browse directories on the olimex site. Is that right?
It's more than a bit pesky when you don't quite know the file name (URL), especially as they're case-sensitive.Edited by JohnS 2011-12-30
