Forum Index : Microcontroller and PC projects : (MM/DM) Powering Maximite SM1 in car
| yobortsa Newbie Joined: 12/12/2011 Location: AustraliaPosts: 37 |
Hi all, I'm wanting to run my Maximite SM1 (with GPS) wired to my vehicle. Surely it's best to put some filtering in, or do you recommend just hooking the cigarette lighter outlet straight to the 12V/Gnd terminals? I skimmed some Silicon Chip articles and they generally seem to use either a 1N4001 or a 1N4004 diode together with a 16V Zener diode/10ohm resister combination to filter transient spikes etc. My electronics understanding is limited, but isn't a 10ohm resister going to limit the current available to the Maximite? How do you guys run the Maximite/DuinoMite in vehicles? Thanks, David |
jman![]() Guru Joined: 12/06/2011 Location: New ZealandPosts: 711 |
Hi I use these Ebay Link Jman |
> LM2596S DC-DC 35V to 33V-5V Step-Down Adjustable Switching Power Supply Module Do you use these at 5V on the USB line or tune them up to 12V? Are you using a Maximite SM1 or Geoff's original version? Thanks, David |
Hi I removed the 5V regulator from the Maximite PCB and set the the DC-DC to 5V out Jman |
I don't think you'd need that for the DM (i.e. just plug it in direct). Anyone can confirm? John |
| Talbit Senior Member Joined: 07/06/2011 Location: AustraliaPosts: 210 |
Geoff recommended a different 5 volt regulator on the MM board and a 33 ohm resistor in series with it. See the first- or was it the second - SC article on the MM. But the switcher is the better way to go if you want efficiency. Running either off the cigarette lighter shouldn't be a problem. Talbit Talbit |
| Olimex Senior Member Joined: 02/10/2011 Location: BulgariaPosts: 226 |
Duinomite and Duinomite-Mega will take any voltage from 9 to 30 VDC as they have DCDC converter the higher is the input voltage less current they will take from the power source |
I Think the main concern was for `Noise Immunity' from things like Alternaters and spark ignition etc.. Olimex should be able to confirm but I am fairly sure the DuinoMite and the Mega have an industrial power supply and noise immunity built in so should handle it easilly. With the MaxiMite and the DuinoMite Mini (+5V) this might be an issue depending on how noisy your +13.8V is and how good a `buffer' the car battery is.. regards, mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
| cmichaelcouch Newbie Joined: 23/10/2011 Location: United StatesPosts: 16 |
I read that anything over 5V might damage a Duinomite-mini. Just thought I would pass that warning on. Michael Couch |
Yes that is True DO NOT supply more than +5V DC to a DuinoMite Mini. It was designed to keep costs low for students and hobbiests.. with the abundance of +5V supplies around these days it shouldnt be an issue. Regards, Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
