Local Time 23:33 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : (MM/DM) Display Options
Posted: 01:26am 08 Dec 2011
Working on a little project, a battery monitor and regulator, and thinking about display options.
First up, has anyone tried the Altronics 40*4 LCD display. I image it would be similar to the standard 16*2 line displays, but want to check there isn't a compatibility issue before I buy one. http://www.altronics.com.au/index.asp?area=item&id=Z7032
Also, looking into a small display that can be used with the Maximite's VGA or Composite video output. A small video monitor, maybe 3 to 6 inches wide. I was looking at car headrest displays but they are a little expensive. Any suggestions?
Gadget
Posted: 02:23am 08 Dec 2011
Hi Glenn,
Having a brief look at the datasheet for that display it mentions compatibility with the HD44780 (which i think is the most commonly used for LCD's) controller so to me that suggests that it should work.
Terry
CircuitGizmos
Posted: 02:33am 08 Dec 2011
Glenn:
A couple of years ago I bought a surplus color composite LCD about 4-5" diag. I can't recall where it came from, but it was made by Intec for a game console. Gamecube? I use it sometimes and it works pretty slick.
You might also look into a portable DVD player. I have one by Philips that has a second screen, and that screen by itself works as a composite display.
rhamer
Posted: 07:28am 08 Dec 2011
  Gizmo said   Working on a little project, a battery monitor and regulator, and thinking about display options.
Be aware that 4 *40 displays are usually 2 displays in a single housing.
The lines often alternate as well, so display 1 is lines 1 and 3 while display 2 is lines 2 and 4
All the control lines are common between displays, except the enable line, so you have to run the init routines twice, once for each display.
Rohan
Rohan Hamer
HAMFIELD Software & Hardware Solutions
Makers of the Maximite Expander.
http://www.hamfield.com.au
trippyben
Posted: 10:14am 08 Dec 2011
I've used the 4x40's a couple of times. If you're not using the R/W feature to check the busy flag and just using delays to make sure stuff happens, you can toggle both enables during the init routines and enable both displays at once without too much drama.
Posted: 03:26am 09 Dec 2011
Ebay have 4.3 inch monitors for under $30 posted.
Search for "4.3 TFT Rear View Monitor" and you will find them.
Posted: 04:19am 09 Dec 2011
Thanks for the feedback.
I dug up an old DVD player that was given to me because it stopped playing DVD's.
The display worked, so I opened it up to see if I could separate the screen from the rest of the unit. No luck, the video controller is part of the main circuit board.
But the unit does have a video input, so I wired in a cable to connect it to a SM1 Maximite set to PAL output. The screen swivels around and folds down, cool, but when I power it up, I need to press several buttons in sequence to select external video source, bummer. It will do for testing.
I'll look into those reversing camera screens. I hope their current draw isn't too much, as I would prefer to leave the screen turned on all the time.
trippyben
Posted: 08:49am 09 Dec 2011
Just use some of the Maxi's digital outs to trigger the buttons in sequence as part of your program init!!!
pcaffalldavis
Posted: 01:10am 10 Dec 2011
The MM SM1 from Dontronics, I don't see that it offers composite video output. Does that mean that the 4.3 TFT displays can't be used with the SM1's?
Could they perhaps be used with a VGA to composite convertor? How fuzzy would the image be? Does anyone have a clear screen shot of a MM screen full of text displaying on a 4.3" TFT?
This might be much better than a 40x4 LCD, and most seem to use only two watts. A very reasonable energy cost as long as they are on the grid.
Pete in Hyder
CircuitGizmos
Posted: 01:19am 10 Dec 2011
U5 Right next to the VGA connector is composite out. Jumper U4 and reboot to get composite.
pcaffalldavis
Posted: 07:16am 10 Dec 2011
Thank you CircuitGizmos.
I think I'll order up a 4.3" TFT. Does anyone happen to have a good quality screen shot of one hooked to a MM with a screen full of text? These 4.3" screens are on Ebay right now for as little as a 20x4 LCD, $20 USD. It might be nice to see just how readable they are though. The text should be very small on a 4.3" screen.
Pete in Hyder
Posted: 11:32pm 10 Dec 2011
My 4.3 inch monitor is a CZ7 model.
Current draw when displaying is 124mA from 13V
68mA when no input.
Pete, If you are running long distances and multiple monitors you might need to install a video amplifier.
I think the monitors come in NTSC or PAL depending on where you live. Mine is PAL.
They are also wide screen so you either loose some screen area by running in 4x3 mode or have a stretched display. If you do your own fonts, they can compensate for the wide screen easily.
Posted: 12:02am 11 Dec 2011
That looks good Jim, just what I need.
Can anyone recommend a ebay seller? There are several that sell the CZ7 and most have good feedback.
Posted: 01:31am 11 Dec 2011
This is the one I have but I don't think there is much difference between suppiers:
www.ebay.com.au/itm/4-3-TFT-LCD-reverse-Rear-View-Car-Video- Monitor-cz7-/280684496311
Bryan1
Posted: 01:46am 11 Dec 2011
Hi Jim,
All I got off that link was :
HTTP Error 404
Page Not Found
Oops! Looks like that page doesnt exist.
The problem is on the link the backshed.com/forum/ is infront of the link. I had to manually remove it before I could get the page to show.
Cheers Bryan
donmck
Posted: 02:35am 11 Dec 2011
URL corrected:
http://www.ebay.com.au/itm/4-3-TFT-LCD-reverse-Rear-View-Car -Video-Monitor-cz7-/280684496311
Thanks Jim, at that price, I had to give one a try. Trouble is it may be delivered after Christmas, which means early January for me.
Cheers Don...
https://www.dontronics.com
Posted: 12:35pm 11 Dec 2011
Ordered one. I figure for the price its worth a try. It would be good if someone in Australia could stock these , they are a good match for the Maximite, and low current draw which suits my needs. So good in fact, why would you bother with a 16 character 2 line LCD when you can have a full 50 character 18 line screen with graphics for a few dollars more.
aargee
Posted: 12:03pm 12 Dec 2011
I'll be interested to see what they're like Glenn. I have a couple of much older composite 7" LCD screens here, and the trouble is that they are NTSC resolution. This pixelates the graphics a fair bit, to the point of being unreadable.
Geoff's support NTSC might work, I haven't tried that yet.
- Rob.
Posted: 03:14am 20 Dec 2011
The little LCD arived today, all the way from China.
Have to say, for the money, its pretty good! The unit has a few menu options, like brightness, contract, colour, and aspect ratio ( 16:9 or 4:3 ). Image clarity is good, though hard to see in the picture below.
Happy
vasi
Posted: 05:09pm 20 Dec 2011
The setup looks nice!
Elvish name: Mablung Miriel
Beyound Arduino Lang
