Local Time 23:06 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Multiple Serial Ports
marcwolf
Posted: 02:23am 02 Dec 2011
Hi Folks.
I do a low of experimenting with the PicAxe and one of the handy things there is that you can make multiple serial ports.
Is there a way to make more than 2 serial ports with the Maximate? Often you might have several additional boards like a VrBot, GPS, Sonar, etc and very quickly run out of Serial ports.
Many thanks
Dave
Coding Coding Coding..
Keep those keyboards coding..
RAW CODE!!!!!
rhamer
Posted: 02:50am 02 Dec 2011
  marcwolf said   Hi Folks.
Many thanks
Dave
No the standard Maximite and its clones only have 2 serial ports (rs232) generated in software like the PicAxe.
The DuinoMite has or is about to have, more (I cant remember the exact quantity but someone will chime in) that are a combination of Hardware based (i.e. supported in the Pic32) and software like the standard Maximite.
Rohan
Rohan Hamer
HAMFIELD Software & Hardware Solutions
Makers of the Maximite Expander.
http://www.hamfield.com.au
graynomad
Posted: 09:07am 02 Dec 2011
[quote]generated in software like the PicAxe. [/quote]
So it could have more, it just hasn't been done.
BTW, how come there's no [ quote] button? Or am I blind?
_____
RobEdited by graynomad 2011-12-03
Rob Gray, AKA the Graynomad, www.robgray.com
Posted: 09:26am 02 Dec 2011
[quote]
_____
Rob
On Right hand side of screen..
graynomad
Posted: 09:32am 02 Dec 2011
Yeah but that quotes the entire post, I guess you can cut what you don't want but on every other forum I use you can quote any old text. Eg
[quote]Maybe I want to quote from a data sheet[/quote]
______
Rob Edited by graynomad 2011-12-03
rhamer
Posted: 10:02am 02 Dec 2011
  graynomad said   [quote]generated in software like the PicAxe. [/quote]
_____
Rob
Unfortunately it's not quite that easy.
In theory your right, but there are some fundamental differences in how a PicAxe is programmed compared to the Maximite.
With micros like the PicAxe and the basic stamp, some of the programming work is done before it is loaded into the chip. This means the chip only has to execute clean tokenised code.
With the Maximite because it is designed to be a stand alone device that requires no compiler, everything has to be done on the chip, including syntax checking and of course servicing the keyboard and running the video. So as you can see, although the pic32 is a very powerfull chip, it has a lot more to do than a PicAxe.
So as with all things there is a limit. software based uarts take processing time, and so there has to be a limit of some sort.
Rohan
Rohan Hamer
Olimex
Posted: 01:19pm 02 Dec 2011
MaxiMite have COM1: and COM2: which are up to 19200 bps made with bit-bang
COM1: have also RTS CTS flow control
DuinoMite keeps COM1: and COM2: implemented same way as MaxiMite, but also have COM3: and COM4:, COM3: go to the UEXT and can work up to 8 000 000 bps at least looking in the source, but never tried it over 115200 bps, COM4: go to the RS232 connector with RS232 driver.
