Local Time 23:06 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : (DM MM) Trapping Hardware Errors MMBas
DuinoMiteMegaAn
Posted: 03:34pm 01 Dec 2011
(DM MM) Trapping Hardware Errors in MMBasic.
Under command "OPTION ERROR" you have two parameters of "ABORT" and "CONTINUE"
This applies ONLY for reading and writing from a SD card. <-----<<<<
Lets say you have I2C RTC basic code and the I2C device is missing.
How do you trap on this error to prevent a program halt?
Code example
120 I2Caddr = &h68
130 I2CEN 100,100
140 I2CRCV I2Caddr, 0, 8, RTCbuff(0), 1, 0
150 I2CDIS
Having the I2C device missing (not connected) will halt/abort program execution with
the following error which halts program execution.
Error Line 140: Receive variable not found.
I need to trap this error BEFORE this halts program execution ... any suggestions?
DuinoMiteMegaAn
Posted: 04:44pm 05 Dec 2011
Trapping errors revisited ...
The "Error Line 140: Receive variable not found" was
caused by not having a DIM RTCBuff(8) assigned.
The I2C should have timed-out and I could have used
"? "0=ok 1=nack 2=timeout"; MM.I2C" to pick up the I2C error.
Edited by DuinoMiteMegaAn 2011-12-07
