Local Time 23:06 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : (DM MM) Key mapping for Function keys
Posted: 05:45am 01 Dec 2011
Hi All,
I wrote a little piece of code to test for various keys and their values
as in
10 CLS: PRINT "press any key to get its value"
20 PRINT: PRINT: PRINT"KEY Value"
30 a$=INKEY$: IF a$="" THEN GOTO 30
40 PRINT a$;" ", ASC(a$)
50 GOTO 30
But F9 doesnt return anything and F11 returns 55 instead of what I believe should be 155..(according to the sequence of F keys)
Regards Mick
PS. This is using USB console. I havent tested PS2 yet .
MickEdited by bigmik 2011-12-02
Posted: 08:46am 01 Dec 2011
What terminal program are you using?
With Teraterm, I get the expected results
F9 gives 153
F11 gives 155
Maximite, MMBasic V2.7B
Posted: 08:49am 01 Dec 2011
  TassyJim said   What terminal program are you using?
F9 gives 153
F11 gives 155
Hmm,
Ok, I am using a DuinoMite 2.7 (based on Geoffs 2.7),
I use TeraTerm so must have been a minor bug fixed in 2.7b.
Posted: 03:53pm 01 Dec 2011
  bigmik said  Ok, I am using a DuinoMite 2.7 (based on Geoffs 2.7),
No, nothing changed in that area.
Posted: 06:23pm 01 Dec 2011
Hmm,
Thanks Geoff,
I will run that one by Ken,
Unless TerraTerm has remapped those keys... I will check the settings and try Putty..
Hmm. Using Putty.. F9 -No response, also F11 no response so the F11 thing might be a TT setting. Still something for Ken I suspect.
donmck
Posted: 07:00pm 01 Dec 2011
Hmm,
Thanks Geoff,
Just checked MM V2.7a and 2.7b, OK in VGA mode
Also checked DM V2.7a and it is OK in VGA mode
Tried MM&DM from TT and I found F9 is OK, F11 = 55
More investigation needed with TT I think.
Cheers Don...
Edited by donmck 2011-12-03
https://www.dontronics.com
CircuitGizmos
Posted: 07:56pm 01 Dec 2011
I just wrote a PC program to display the keyboard key codes. No routing through TT, no MMBasic stuff, just display the key code in a box.
F11 and F12 display nothing. I think that the operating system grabs them first.
Bryan1
Posted: 08:19pm 01 Dec 2011
G'day Guy's,
I spent most of yesterday and last night getting all the commands finished on that help file and today I'll setup both the SM1 and the DM and test it out on the VGA. Just need to do a bit more tweaking then I'll release the code for people to have a play with it. Now I did try for while to try and map the F1 key so it would start up the file with no luck. Basically the main 'help file' is in a folder on the SD card called help. I do feel it would be a huge bonus for when a user wants to see the help file simply pressing F1 like on all computers will bring it up.
Regards Bryan
donmck
Posted: 09:23pm 01 Dec 2011
Cheers Don...
Got closer to the bottom of it.
In TT there is term setup >> term ID >> then a whole range of emulation modes. I tried every one of them, and although the returned code changed, it never gave the expected result. I also tried coding receive changes, but no joy.
Then I saw that you can open a new window in "TEK" mode, and bingo, correct results.
I didn't find out how to enlarge the small screen, and save the settings, but that is for another person, or another time.
Cheers Don...Edited by donmck 2011-12-03
