Forum Index : Microcontroller and PC projects : Duinomite Not seeing the SDcard
Bryan1
Posted: 03:58am 21 Nov 2011
G'day Guy's,
Well my DuinoMite turned up today and got a bit of a shock at the start, I used my old IBM 14" monitor and no screen output at all. Anyway I loaded up MMIDE and finally got the output so I knew the duinomite was alive. I connected up another monitor I have here and all was good. Now I have a 2 gig micro SDcard here so I put it in my small usb dongle and reformatted it to FAT. Then I placed some of the example bas files on it and no matter what I do it keeps saying error file not found. Now I noticed 2 leds are lit one is the green led by the user button which is on full time and also beside the battery charger input is a red led that is always on. Now i'm not sure if that red led is showing some sort of error.
Another little problem I found was when I first connected it via USB it said new hardware found and the DunioMite name did come up. Noway would it finish correctly so I came back down to the house and loaded up those files on Don's Site and that fixed the problem. Anyway having a heap of fun here learning my way around it all but not being able to see all those files I put on the SDcard is a bit worrying.
Regards Bryan
DuinoMiteMegaAn
Posted: 04:47am 21 Nov 2011
You said "file not found" ...
Just curious, what is the "variable" MM.ERRNO? (#6 Cannot find file)
or other?Edited by DuinoMiteMegaAn 2011-11-22
Bryan1
Posted: 05:05am 21 Nov 2011
TIS ok I worked it out, I took the SDcard out and wiped all the files off then copied them back over sill no go. So did a reboot and just typed in 'files' next thing they showed up. I do the problem was I didnt have autorun.bas on the card so that could of been the problem all along. All a new learning curve so soon I'll start writing my first program and get on designing and making a box to suit the Duinomite and the addon board.
Cheers Bryan
donmck
Posted: 05:35am 21 Nov 2011
  Bryan1 said   TIS ok I worked it out, I took the SDcard out and wiped all the files off then copied them back over sill no go. So did a reboot and just typed in 'files' next thing they showed up. I do the problem was I didnt have autorun.bas on the card so that could of been the problem all along. All a new learning curve so soon I'll start writing my first program and get on designing and making a box to suit the Duinomite and the addon board.
Cheers Bryan
Hi Bryan.
Like all new things, it takes a bit of getting used to.
Two things.
The red LED is the power LED, so it is always on.
You don't need the autorun.bas program on the SD card.
If you press the reset button, the yellow LED will go out. This is switched on by MM-Basic, and left on. We will make it PIN(0) at some stage in the new DM firmware.
This means you will be able to control it from Basic.
Cheers Don...
https://www.dontronics.com
sparkey
Posted: 05:38am 21 Nov 2011
the sd card does not like being hot swapped
DuinoMiteMegaAn
Posted: 12:26pm 21 Nov 2011
Don, Per the rev. C Mega schematic there are 3 LEDS.
Red LED = Power Indicator
Yellow LED = D9/PIN#20/VGA VSYNC
Green LED = ?
Don, the yellow LED is already tied to PIN#20, so in new firmware, "in the future",
PIN#0 will also be tied to PIN#20?
sparkey
Posted: 12:54pm 21 Nov 2011
the yellow led lets you know that the chip is functioning the red led lets you
know that the power is correct and functioning..when the green an yellow leds are flashing intermittemt this is when the board is in boot loader mode ...otherwise the green led flashes when there is sd/flash drive actiivity on occurence....
DuinoMiteMegaAn
Posted: 01:28pm 21 Nov 2011
Sparkey - I think you missed my point to Don.
It would be very unwise to control this yellow LED with PIN#0.
It is also tied to PIN#20 VGA VSYNC which is indirectly used for "chip is functioning"
sparkey
Posted: 01:33pm 21 Nov 2011
what ever the point is that ..the red led is power on the yellow led is ..how ever you want too interpret it "chip power" the green led is the sd card....
donmck
Posted: 01:57pm 21 Nov 2011
  DuinoMiteMegaAn said   Don, Per the rev. C Mega schematic there are 3 LEDS.
Green LED = ?
Sorry, my typo, too many ideas.
Make that the Green LED, which is SD Card activity.
Idea is to be able to flash the LED via PIN(0), if there is going to be SD card activity, the status of the green LED is saved, SD card is accessed, green LED flashes as it should, then green LED status is restored.
I don't see a problem with that, can anyone see a flaw?
BTW
Ken has the current firmware alternatively flashing the yellow and green LEDs when it enters boot mode.
Cheers Don...Edited by donmck 2011-11-23
elchucko
Posted: 07:17pm 21 Nov 2011
A couple questions came to mind as I read these posts. I have a Maximite SM1. Do not "hot swap" the SD card? My PIC32 card's green (D4) LED stays on solid with power on. In boot mode it flashes. At power up the Red (D5) flashes once. Comments?
Vikingboy
Posted: 07:28pm 21 Nov 2011
Hi elchucko,
That is standard behaviour for an SM1, also I always "hot swap" the SDcard with no ill effects, I would be surprised if anyone turned the power off to change the SDcard, of-course I wouldn't do while in the middle of a read/write operation :)
Andrew
elchucko
Posted: 07:35pm 21 Nov 2011
OK, great. I just noticed a previous comment advising not to hot swap (which I've been doing now for some time). Thank you
larny
Posted: 09:36pm 21 Nov 2011
  Bryan1 said   G'day Guy's,
Regards Bryan
G'day Bryan,
I'm confused by this thread.
I bought my Maximite from Altronics via Semtronics. I'm having the same problem. It gives an error when the SD card is inserted.
I have not yet tried putting autorun.bas on the card as you did. Besides, someone said it is not necessary.
Also, in the thread a Yellow LED & Reset button are mentioned. My MM does not have these. So is the DuinoMite a little different to the MM?
BTW, I always insert the SD card before I turn the power on & turn it off before removing it. There appeared to be conflicting opinions on this point.
Any advice on these issues will be appreciated.
Len
sparkey
Posted: 09:48pm 21 Nov 2011
generally any hot swapping of the sd-card is not recomended...sparkey...///...///...///
Posted: 10:11pm 21 Nov 2011
Yes, the DM and MM are somewhat different, though they have many things in common.
There are detailed posts about the differences, here and elsewhere (from Don and others) - and of course the circuit diagrams are fully open if you want to study them (a good idea but not the easiest of tasks).
My DM has red (power), yellow & green LEDs. I don't have a MM (mainly because by the time I stumbled on it the DM was already out and I liked its design better - not a criticism of the MM because it's easier to improve than originate!).
I believe you don't need an autorun.bas
Maybe the SD system is just a little buggy?
Posted: 10:36pm 21 Nov 2011
The way the Maximite works is that it will detect the removal/insertion of a card (even while running a program) and reset the file management routines in MMBasic to prevent corruption. So hot swapping a card is OK on the Maximite.
The DuinoMites do not do this and MMBasic can get confused as it does not know about the removal of the card. The solution is to always cycle the power after removing a card on a DuinoMite. This also applies to the Maximite-EV.
Note that in all cases you should always close all files before removing a card.
James_From_Canb
Posted: 11:05pm 21 Nov 2011
I had a similar problem the very first time I used the SD card on my Altronics Maximite. It didn't seem to recognise the card.
I think my solution was to save a file to the card. Since then I've never had a problem.
I know that's not the same as Bryan's problem, but people with SD card problems are likely to read this thread.
Also, it might be worthwhile checking the soldering on the SD card cage contacts. Some strange SD card behaviour in other threads was found to be caused by faulty soldering.
Bryan1
Posted: 11:17pm 21 Nov 2011
Hi Guy's,
I brought the Duinomite down to the house last night and hooked it up to this ol' 32 bit puter, once I got the duinomite installed as a USB drive I had hours of fun playing with it. First I was using the latest MMIDE I downloaded off Don's site and there are still a few bugs on there. Like when I ran the datalog.bas file the mouse disappeared form the MMIDE screen and even resetting the board didn't stop the error. I downloaded tera term and it worked great so later today I will ahve a go at writing some code.
Regards Bryan
larny
Posted: 08:14am 22 Nov 2011
  JohnS said   Yes, the DM and MM are somewhat different, though they have many things in common.
Thanks Johns,
I did a brief search for the DM circuit but coiuld not find it. Your explanation that it is a little different & has 3 LEDs is sufficient for me sincer I have a MM.
I am intending to check the connection to the SD card socket, but have been distracted by what appears to be pin numbering erros in the Silicon Chip circuit.
It is different to the one posted by Geoff G.
BTW, Geoff if you read this, please note that I have found an error in the MM circuit posted on your site.
PIC pins 62 & 63 are both labled RE3. I assume one is in fact RD3. I'll check it against the Microchip spec later & post the result.
Len
