Local Time 00:26 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Wii Numchuck
jman
Posted: 11:27pm 19 Nov 2011
Hi All
I have seen a few interfaces based on the Wii numchuck
so i decided the Maximite needs one too.
The Numchuck uses' an I2C interface
The I2C address is &h52 and used in the "New Way" so the data in unencrypted
The Initialize sequence is 2 bytes &hF0 and &h55 this only needs to be done once.
Then set the read location to &h0 and read the required 6 bytes
This litle gem provides a X-Y Joystick a 3 Axis Accelerometer and 2 butons
not bad for $3.50 shipped
Info on the Numchuck was sourced from here
Wiki on Wiimote
The Numchuck was souced from here
Ebay Numchuck
And the code is here
2011-11-20_091652_Maximite_NumChuck.zip
Jman
crackerjack
Posted: 12:11pm 20 Nov 2011
Hi jman,
Nice find and a good post. I've ordered a few of those little suckers - 3-axis accelerometer + 2 buttons + analog joystick for less than the price of a cup of coffee - delivered! I have some ideas to put them to some good use, but will obviously want to experiment first...
Just a quick technical question while I await delivery... did you have to use pull-ups, or are they already in place on the device? Also, is 5.0V ok? Any idea on current drawn by them?
Thanks again for the good info.
Cheers,
crackerjack.
jman
Posted: 06:27pm 20 Nov 2011
Hi crackerjack
I am using the 3.3V from the Maximite 3.3v rail
Current consumption is 7.5ma so no troubles there.
My Maximite has an RTC with pull-ups to +5V so i just left those in place.
Hope this helps
Jman
jman
Posted: 05:24am 21 Nov 2011
Hi
Oone small gotcha the clone numchuck was odd colored wires
they are
White - SDA
Blue - SCL
Red - Ground
Yellow and Green - +3.3v
Thought i would make it a little easier for those you are going to try one
Jman
marcwolf
Posted: 11:27am 21 Nov 2011
Great project
The little IR camera in the remote is also a very interesting little device. Shoudl work great with the Maximite
Coding Coding Coding..
Keep those keyboards coding..
RAW CODE!!!!!
crackerjack
Posted: 07:26am 07 Jan 2012
Reviving an old post...
I obtained a bunch of these extra cheap items from ebay and they are great. Really handy as hand-held controllers for almost anything and all via the I2C bus on the Maxi/Duino.
To get the full 10-bit resolution data from the accelerometer's 3 axes, here are a couple of changes that can be made to jman's original code:
[code]
Accel_X = (RDBuff(2) * 4) + Fix(RDBuff(5)/2^6)
Accel_Y = (RDBuff(3) * 4) + Fix((RDBuff(5) And &b00110000)/2^4)
Accel_Z = (RDBuff(4) * 4) + Fix((RDBuff(5) And &b00001100)/2^2)
[/code]
Also, it's really easy to make a "breakout board"/adapter for the Nunchuck connector using a bit of old stripboard or better still some double-sided edge connecter from an old PCI card, etc.
Have fun...Edited by crackerjack 2012-01-08
yobortsa
Posted: 07:04am 13 Jan 2012
I just received some clone nunchuck controllers from eBay and they have different colour coding to what jman listed above. Mine are:
White - SDA
Yellow - SCL
Black and Brown - Ground
Pink - +3.3v
The pinout is shown on the board if you open the controller:
VCC Pink
DET Blue
SCL Yellow
SDA White
GND Brown/Black
I believe the blue wire is used for device detection on the WII and is tied to VCC, hence doesn't seem to be required on the Maximite.
Here is the Maximite 3.0A code I'm using:
Rem ReadWii Numchuck
Cls
GoSub Screen
50 Dim RDbuff(6)
60 i2caddr = &h52 ' Numchuck address
70 I2CEN 400, 100 ' Enable I2C
80 I2CSEND i2caddr, 0, 2, &hF0, &h55
90 I2CSEND i2caddr, 0, 2, &hFB, &h0
DisplayLoop:
I2CSEND i2caddr, 0, 1, &h0
I2CRCV i2caddr, 0, 6, RDBuff(0)
Joy_X = RDBuff(0)
Joy_Y = RDBuff(1)
Accel_X = (RDBuff(2)*4)
Acc_X=Accel_X+Fix((RDBuff(5) And &b00001100)/2^2)
Accel_Y = (RDBuff(3)*4)
Acc_Y=Accel_Y+Fix((RDBuff(5) And &b00110000)/2^4)
Accel_Z = (RDBuff(4)*4)
Acc_Z=Accel_Z+Fix((RDBuff(5) And &b11000000)/2^6)
If (RDbuff(5) And &h01) <> 0 Then
Button_Z = 1
Else
Button_Z = 0
If (RDbuff(5) And &h02) <> 0 Then
Button_C = 1
Else
Button_C = 0
Locate 111, 10 : Print Format$(Joy_X, "%3.0f")
Locate 160, 10 : Print Format$(Joy_Y, "%3.0f")
Locate 111, 50
Print Format$(Acc_X, "%5.0f")
Locate 160, 50
Print Format$(Acc_Y, "%5.0f")
Locate 210, 50
Print Format$(Acc_Z, "%5.0f")
Locate 120, 90
Print Button_Z;
Locate 169, 90
Print Button_C;
GoTo DisplayLoop
Screen:
' Setup Screen
Locate 0, 0
Print "Joystick Position X Y";
Locate 0, 40
Print " Postion Sensor X Y Z";
Locate 0, 80
Print " Buttons Z C";
Return
I question if crackerjack had the right bits for the extra two-bit resolution on the X and Z axis - his code doesn't seem to match the website:
http://pinouts.ru/Game/nintendo_nunchuk_pinout.shtml
I think I've written the code according to this website, but it's probably not really worth using the extra two bits anyway - too hard to move the controller in fine increments.
It's a great little device for the menu on my car computer...
DavidEdited by yobortsa 2012-01-14
crackerjack
Posted: 10:01am 13 Jan 2012
David. Thanks for pointing out the error in the code snippets I posted. They are incorrect and your updated code is correct.
Cheers.
BobD
Posted: 05:24am 16 Feb 2012
I received a couple of Nunchuks today. They have a plug on them like nothing I have ever seen before. What have you guys done to get them talking? Do you take the plug off?
Bob
jman
Posted: 05:34am 16 Feb 2012
Hi Bob
I just cut the plug off mine but if you dont like that idea
take a look here http://olimex.wordpress.com/2012/02/07/duinomite-new-boards- t-shaped-breadboard-adapter-wii-nunchuk-to-uext-and-icsp-ada pters/
BobD
Posted: 05:50am 16 Feb 2012
Thanks John
I have an MM so it looks like I will be cutting the plug off.
Post was 10 days from HK. Not too bad.
Bob
crackerjack
Posted: 05:57am 16 Feb 2012
Aaargh! Don't cut it just yet!
I made a small adapter from a stripboard edge, but a PCI card edge would work better. When a get a moment this evening from home, I'll post some pictures and details of the "adapter" I made.
Cheers.... and put those cutters down!
BobD
Posted: 09:25am 16 Feb 2012
  crackerjack said   Aaargh! Don't cut it just yet!
CJ
The cutters are down. No rush I won't do anything tonight (or tommorrow).
Bob
crackerjack
Posted: 12:19pm 16 Feb 2012
The home-brew adapter is a bit rough, but works pretty well.
You will need a bit of stripboard of the sort that has vertical and horizontal copper strips (although the orginal Veroboard type might work with some ingenuity). You wil also need some single strand insulated wire, and 5 header pins. See below for stripboard I used:
Cut the board so that you have three strips (vertical) at the edge and a couple of horizontal strips. A little bit of sanding and trial (avoid error) and you can get a little board that fits snugly into the Wii socket. The width is about 6mm, but it's best to start a bit wider and sand slightly until the fit is just right. See below:
Next, solder a couple of "whiskers" onto the board. A (blurry) picture tells a lot of words; the main thing to note is that you should leave the insulation intact on the wites and solder one into each of the "horizontal" strips at the edges of the board. Leave enough wire to work with for later. See below:
The next bit involves soldering header pins onto the board. The three pins going into the "vertical" strips at the edge of the board need to be soldered over the wire "whiskers" from the previous step. The pins will only just protrude through the board so thay can be soldered. Two pins are also soldered into the "horizontal" strips in the centre holes. More fuzzy, small images follow:
Almost done. The last bit is a little tricky... The protruding whiskers need to be squeezed into the tiny holes above the slot on the Wii socket. As the board is pushed into the slot, small springy metal tabs move up into these holes and so hold the wires in place. The trick is to get the wires in first before the board wedges the springy metal bits up too hard to get the wires into the gap. It may help to cut the wires to the right length (about the end of the board) and then very carefully, with *sharp* wire cutters, give the wires a chisel edge by cutting them diagonally at the end. It is important that the wires go into the two holes on the Wii socket where the middle connector is Unused, i.e. SCL & GND (image below borrowed from the WiiBrew wiki) and the edge connector part of the board connects to the VCC and SDA lines. The middle of these connections is of no importance to us:
Finally, according to the connection labelled above, connect to your Maximite using some standard female connector leads. Voila:
After all that hard work, grab a cold beer (mind you don't spill it on your benchtop), fire up the Maxi and have so much fun with your Wii Nunchuck that your wrist hurts.
I'll be posting a full Wii Nunchuck Demo program in a day or so.
Cheers - crackerjack.
ArtBecker
Posted: 02:37pm 16 Feb 2012
There are several inexpensive commercial adapters available. Just do a Google search on Wii Nunchuck (or Nunchuk) Adapter.
Remember, this is an I2C device, so the best adapters make provisions to add additional I2C devices.
ksdesigns
Posted: 05:33pm 16 Feb 2012
http://www.sparkfun.com/products/9281
ken
Olimex
Posted: 06:02pm 16 Feb 2012
Ken, our first design was like this and it easily slip off the joystick
so we made this MK2 design:
ksdesigns
Posted: 08:17pm 16 Feb 2012
very nice much better the others keep coming out ..
ken
BobD
Posted: 05:52am 23 Feb 2012
  Olimex said   Ken, our first design was like this and it easily slip off the joystick
It looks good. Do you sell it? I looked at olimex and dontronics and could not find it. Link?
