Local Time 22:41 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DuinoMite-Mega corrupted HID packet
Posted: 02:34pm 18 Nov 2011
(new member alert: hi guys!)
I am using the DM-Mega (Rev C, it has MMBasic 2.7) with Linux, which (as expected) logs a message when the board is reset to the bootloader. dmesg shows the message OK except that there are bad bytes in it.
Using C-style \xhh escapes to show the bad chars:
new full speed USB device using uhci_hcd and address 52
New USB device found, idVendor=15ba, idProduct=0033
New USB device strings: Mfr=1, Product=2, SerialNumber=0
Product: DuinoMite
Manufacturer: Olimex \xE4\x90\xA0uinoMite
(I've reduced the output a bit as it's not exactly brief)
Maybe this is akin to the truncated Basic sign-on message, but this time it's the bootloader that's affected.
Anyone else able to confirm this? (I suspect you won't see any message on Windows, corrupt or otherwise.)
Also - how do I report this to Olimex? I guess Ken? Do I post here and hope or what?
Would I need a PICkit3 or similar to be able to reflash the bootloader?
Thanks,
sparkey
Posted: 03:01pm 18 Nov 2011
welcome to the back shed... i see i am not the only one with a duino mega good finally at last... i got mine yesterday and as far as linuix goes "i`m soory but i have no idea here out of my terra tory" but if you have corrupeted the chip i really dont se how but yes prolly a pickit ....that is all i know on this subject i`m sorry that i cannot be of further help....oh you need the bootloader that has been specially designed for the "duino" go to "dontronics" and find the ftp page and you will find all the nesscary files there um there is no new version of the firm just yet but there will be one out shortly ..couple of days ...the firm flash is different to the origanal maxi as the "duino" is the same chip ...but it functions differently and the headders are different if you want to run an "rtc" i have one on mine it does use pins "five and six" of the "U-ext" and it also requires that you have a five volt and ground ..negative... i will be up for god knows how long just post any thing in your subject peop`s will look and get back to you ...and yes i would ask ken about your linux problem ...///...///
Posted: 03:27pm 18 Nov 2011
Thanks for the welcome.
I don't believe I have corrupted the chip. It is how the bootloader is, shipped from the factory. I'm saying I believe it is a firmware bug and asking how do I report it to Olimex to get it confirmed / fixed?
sparkey
Posted: 03:39pm 18 Nov 2011
ok then yes try ken as he`s the "duino" guru of the firm code...."kdsdesigns"...
Vikingboy
Posted: 03:58pm 18 Nov 2011
Hi John,
I am just guessing here, but, in other threads on this forum you will see that using the Duino boards on USB via terminal users have reported corrupted output, ie. some scrambled letters etc in the boot message etc.
Perhaps what you are seeing is a related problem ? I believe Olimex and Ken etc are aware of it and working on a fix. Idont think it seriously affects useability and apparently not at all if you connect VGA or composite video out.
as I said just a guess.
rgds and welcome.
Andrew
PS
Olimex et al. read this forum regularly.Edited by Vikingboy 2011-11-20
sparkey
Posted: 04:15pm 18 Nov 2011
thanks andrew i forgot about that ...sparkey....
donmck
Posted: 07:04pm 18 Nov 2011
Hi John,
I'll forward this thread onto Tsvetan of Olimex and Ken. They read basically everything, but of course could easily miss this.
I am having trouble understanding in full, but if it is about the log on initial power up message being corrupt and nothing else, then I had hoped to have new firmware to fix this small problem by now.
Cheers Don...
https://www.dontronics.com
Posted: 07:37pm 18 Nov 2011
Thanks, Don. I reckon whoever changed the bootloader will know what's wrong fairly quickly.
I suppose the modified HID bootloader sources must be somewhere..... I didn't find them, though :(
Got them?
donmck
Posted: 07:49pm 18 Nov 2011
  JohnS said   Thanks, Don. I reckon whoever changed the bootloader will know what's wrong fairly quickly.
Got them?
The bootloader is Ken's department.
Here is the link to my files for the DuinoMite.
http://www.themaximitecomputer.com/max/Programs/index.php?di r=Hardware%2FDontronics%2FOlimex%2FDownload+Files%2F
I don't know if it is included in the zips. You may already have the same files.
BTW
The reason why I have this code on my site, is that when Olimex changes a file name, then every link on every dealers page (including mine) is then wrong. I link to a directory, not a specific file. I would rather just upload a new file, than continually change links on multiple products.
If a common file storage is found, then I will redirect one link to that storage area.
In the case of the DuinoMite, I usually know about the updates anyway, and can generally post them immediately.
Cheers Don...Edited by donmck 2011-11-20
Posted: 08:03pm 18 Nov 2011
Thanks. I already found those files and they don't seem to have the bootloader source unless I missed it. Not a big issue at all, certainly not urgent. I can see various people have their hands pretty full!
You're running a sort of mirror, which is by no means a bad thing. The opposite, really, except I suppose the usual risk of being out of step. Doesn't appear to be broken so doesn't need fixing :)
Posted: 08:39pm 18 Nov 2011
Got them?
Hi John,
I believe the bootloader is `owned' by each supplier or entity. As they insert their own PID/VID (product and Vendor ID)information in them...
I dont believe that Geoff released the source for his and I am certain Ken rewrote the bootloader from scratch, the Boot button acts on a different PIC pins for a start..
The corruption at boot, I believe, is from Ken experimenting with displaying a graphic Logo on the VGA screen (removed from the first release) on power up. Ken extended the amount of text that is displayed on reset/boot and believes that the `screen' corruption is a simple USB buffer overflow..
That will definately be fixed , maybe it should have been fixed in the first release but we were trying to get them out there quickly.
As for the corruption you mentioned... I dont understand the details there, I will leave that to Ken to investigate.
Just a thought.... You have putty (or your terminal prog) set to 38400 8bit No parity?
Edited by bigmik 2011-11-20
Posted: 09:18pm 18 Nov 2011
Good points. It may indeed not be open source (and anyway it's likely a few tweaks to the Microchip USB HID bootloader).
The bug concerned will not be seen in putty. I believe it's part of the USB endpoint negotiating with the host (in effect, during a connect rather than subsequent to an open - which is when putty could see it). Baud rate is irrelevant at this stage of a USB device announcing its presence because the device isn't a pseudo-COM port and has no settable baud rate (*). Linux tends to log such device-negotiation things (via syslog, so it ends up where dmesg can get at it).
No worries, I expect Ken or someone will fix it.
I have a PICkit3 clone but even so will struggle to replace the bootloader due to the non-standard ICSP connector on the board :( unless the bootloader can replace itself. (Yes, I know I can buy a special ICSP plug etc.)
I don't think it NEEDS replacing (am not sure), but it sure is ugly to have weird bytes where clearly others should be.
(*) edit: actually, the HID bootloader isn't a pseudo COM-port so never does have a settable baud rate, just saying this for completeness. You won't be able to talk to it using putty. Have a look at the code for such as mphidflash if you're interested.
JohnEdited by JohnS 2011-11-20
Posted: 09:46pm 18 Nov 2011
Oh, bad words!!
My original post (and the rest consistently so) is wrong :(
It's not during the bootloader negotiation that the bad bytes are sent, it's during the ordinary (non-bootloader) negotiation.
Aargh. Sorry.
It's still a bug just it's when the board is saying (to the USB host) that it's a DuinoMite rather than when it's saying it's a HID bootloader.
Ken's gonna kill me.
Don - please let Ken know the above.
donmck
Posted: 10:06pm 18 Nov 2011
  JohnS said   Oh, bad words!!
I doubt that John, and it's only the doers that make mistakes.
If you sit there fat dumb and happy, you will never make a mistake.
I put both Tsvetan and Ken onto this thread, so I know it will be looked at.
Posted: 10:17pm 18 Nov 2011
Thanks, Don.
I still feel a fool, but at least there IS a bug.
Posted: 12:48am 19 Nov 2011
  donmck said   it's only the doers that make mistakes.
Cheers Don...
I thought I made a mistake once but when I checked again I was mistaken
rhamer
Posted: 03:07am 19 Nov 2011
  donmck said   .....If you sit there fat dumb and happy, you will never make a mistake. ...
Hey...... I resemble that remark.......
Rohan
Rohan Hamer
HAMFIELD Software & Hardware Solutions
Makers of the Maximite Expander.
http://www.hamfield.com.au
ksdesigns
Posted: 03:39am 21 Nov 2011
see if this one fixes you usb problem ..
so other fixes also
Editor still not done sorry
works better on serial console have some scroll issues on vga
you can test it with
fse "filename.bas"
changed it from editor to fse now..
ken
MMBasic-Olimex-2.7-ksd-11-20
Posted: 10:19am 21 Nov 2011
Ken,
Thanks. It fixes the corrupted bytes in the USB report found in dmesg.
But when I log on to the board (using screen /dev/ttyACM0) I get:
Exception code 0 at 0x0
An internal error was trapped (sorry).
If I press a key, I then get the Maximite BASIC Version 2.7 sign-on, then:
So it looks like the USB part is OK but something else is broken.
edit: I see sparkey looks to have updated to the new firmware OK so I wonder what's going wrong for me - maybe mphidflash needs a tweak for the board or something? I see the Windows firmware flasher uses Qt etc - is the flasher available for Linux (or can I build it)?
BTW, any Linux users, this is what I did to update the "firmware" (MMBasic):
1. made sure I had something appropriate in /etc/udev/rules.d in my case in
a file 41-microchip.rules where I added:
# DuinoMite (PIC32MX)
ATTR{idVendor}=="15ba", ATTR{idProduct}=="0032", MODE="0660",GROUP="dialout"
(I'm a member of group dialout but use any group you like and are a member of; note that if you add a new group I believe you need to log out & back in)
2. Then I used mphidflash, which is on the net, like this:
mphidflash -v 15ba -p 0032 -w Olimex.X.production.hex -n -r
which sends Ken's file to the DuinoMite (mine's a Mega) and then resets it
I'm puzzled why I need "-n" (don't verify) but it fails the verify otherwise
The -v and -p are the HID device vendor & product ID which I got from dmesg | tail after plugging the board in and resetting it to the bootloader.
Edited by JohnS 2011-11-22
