Local Time 22:30 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Teraterm - presets
aargee
Posted: 02:15am 18 Nov 2011
I'm using Teraterm when playing with the Maximite, but also use it for mucking around with Bus Pirate and a few other serial applications.
Now, I'm probably missing the bleedin' obvious, but where/is there a way to save the Maximite setup as a preset (serial port, baud rate, etc), then another for the Bus Pirate, etc. So one click sets up TT for each application?
Rob
(probably soon to have sheepish look on face).
BobDevries
Posted: 02:22am 18 Nov 2011
Rob,
you can put that sheepish look in place now.....
in the SETUP menu there's a selection "SAVE SETUP". You can change the name from TERATERM.INI to anything you want. Then also in the SETUP menu, there's RESTORE SETUP.
Hope that helps.
Bob Devries
Dalby, QLD, Australia
Posted: 06:44am 18 Nov 2011
And then when you have the new INI files, you can start Teraterm with those INI files from separate desktop icons.
That saves a few mouse clicks!
Check the help file under command line /F option.
aargee
Posted: 12:30am 19 Nov 2011
Thanks Gentlemen,
I'll have a play.
- Rob.
