Local Time 22:29 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Maximite SM1 Question
elchucko
Posted: 09:18pm 17 Nov 2011
Oops, I was too quick to post. I found my answer. Edited by elchucko 2011-11-19
CircuitGizmos
Posted: 09:24pm 17 Nov 2011
It should display all of these words:
Maximite BASIC Version 2.7A
Copyright 2011 Geoff Graham
> _
The underscore should blink on VGA (and isn't there at all for a terminal connection.)
sparkey
Posted: 09:30pm 17 Nov 2011
goto geoffs web site down load the latest firm ...your board has .. an all ready loaded firm that is out of date ...///we are up to 2 point 7 ....
also if you are powering via the usb cable from your pc thats fine ...u need to also download the usb drivers if you want to run a terminal program but not nesscary if your just loading new firm ware all u need is the net framework 2 point zero orlater and a c++ compiler if your running win seven it should have this all ready ....///..//Edited by sparkey 2011-11-19
elchucko
Posted: 05:57am 18 Nov 2011
I have the Maximite SM running both standalon
e and via usb and HT on my PC. Thanks for your help.;)
sparkey
Posted: 06:00am 18 Nov 2011
cool from sparkey its nice to get a thank you as manners dont cost a "cent" cool
