Local Time 22:28 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Mailing
elchucko
Posted: 02:59pm 14 Nov 2011
Any idea on how long it takes fora Maximite order to reach the US?
CircuitGizmos
Posted: 03:35pm 14 Nov 2011
"It depends" might be a good answer.
Don't forget to account for Veteran's Day (U.S.) (no post).
I got mine in about a week or so from Oz - from Dontronics.Edited by CircuitGizmos 2011-11-16
pcaffalldavis
Posted: 10:16am 15 Nov 2011
Hello elchucko,
Greetings from Alaska.
Ordered my first SM1 September 24th, arrived in Alaska Oct 3rd, 10 days.
Ordered #2 & 3 SM1s October 16, arrived in Alaska Oct 27, 11 days.
Ordered #4 & 5 SM1s November 6, should arrive tomorrow, I hope!
These are the greatest.
I saw where you were wondering what powered these little giants. Mine don't run on 6 volts. I've had no trouble powering them with anything from 8 VDC to 14 VDC. I have never used the USB connection to power them. I prefer to use them as stand-alone computers. Sounds like that is your plan too so thought I'd share this in case you didn't see it noted elsewhere.
Cordially,
Pete in Hyder
sparkey
Posted: 10:24am 15 Nov 2011
that is odd are you shure that they wont run on 6 volts mine is....
elchucko
Posted: 07:17pm 15 Nov 2011
I plan to use a PC usb port. When standalone I want to use a 120 AC to 5v DC switching converter, the type used to charge cell phones, etc.
sparkey
Posted: 07:30pm 15 Nov 2011
you will need a plug pack that can put out at least 150 ma and 6 volts five may run it but the power when powered from the power sockt/terminals goes directly to a 5 volt reg then the out put of the five volt reg is fed to the three point three volt reg....generally where the volt regs are concearned its a general rule to have two volts over the reg voltage out put....
donmck
Posted: 09:23pm 15 Nov 2011
If you use the elcheapo ebay type, AC to USB 5VDC units to power via USB, they work fine.
Look under power at:
http://www.themaximitecomputer.com/maximite-control/
Cheers Don...
https://www.dontronics.com
elchucko
Posted: 11:01pm 15 Nov 2011
Yes I bought a 120 ac to 5v 1 amp charger from Wal*Mart. If it doesn't work I'll just return it to WM and punt. While reading many posts here on a variety of subjects concerning the Maximite (going back to June), I saw the learning curve on this product and know I'll be going through the same thing except you've "paved " the way. ;)
CircuitGizmos
Posted: 11:18pm 15 Nov 2011
elchucko: If it doesn't work, let me know and I'll send you something that does work. You have an SM1?
elchucko
Posted: 12:50am 16 Nov 2011
Yes I have an SM1. I'll post the results of my "test". Thank you
elchucko
Posted: 12:36am 18 Nov 2011
I received a Maximite toady!
BobDevries
Posted: 12:41am 18 Nov 2011
  elchucko said   I received a Maximite toady!
Heh, is that a new model? Did I miss an announcement?
Bob Devries
Dalby, QLD, Australia
sparkey
Posted: 12:47am 18 Nov 2011
bob the duinomites are available from don....
CircuitGizmos
Posted: 12:52am 18 Nov 2011
The Maximite toady is available from Kermit the Frog.
Bryan1
Posted: 04:05am 18 Nov 2011
WAAAAAAAA Ozzie post used to post my stuff from Don overnight just about everytime so this little puppy was too keen to go check the mailbox at the PO.
One weeping puppy until monday WAAAAAAAAAAAAAA
donmck
Posted: 04:30am 18 Nov 2011
  Bryan1 said   WAAAAAAAA Ozzie post used to post my stuff from Don overnight just about everytime so this little puppy was too keen to go check the mailbox at the PO.
Sorry Bryan, it appears Sparkey is the only customer in the world, that has a DuinoMite.
The first were posted out Wednesday, so I would hope that others would have had them for the weekend.
Cheers Don...
elchucko
Posted: 05:45am 18 Nov 2011
Actually I have a Maximite SM1. I have the device up and running both standalone and on my PC via Hyper Terminal.
