Local Time 22:42 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Maximite SM1 RTC Sucess
     Page 1 of 4
jwettroth
Posted: 03:01am 29 Oct 2011
I noted on the SM1 schematics and board that there is a place for an RTC. I studied the schematics a bit and thought that it would be a matter of populating the parts and writing a little I2C hack in basic. Unfortunately unlike the SPI mode, the I2C commands only address pins 12 and 13 directly. It also looks like the designer of the board thought he was connecting to an alternate SDA and SCL but made an error and used one line but not the other. I considered hacking something in assembly and recompiling, etc., etc. but came up with something simpler. I put the RTC chip down on the board and then connected it to the regular I2C port that is supported by basic. Due to some fortuitous routing and placement of via's, this is a pretty clean mod.
I ordered a PCF8563 and populated the other parts as in the schematic. I kluged up a coin cell holder from some brass stock I had laying around as can be seen. (it works...). <see photo- RTC Long Shot>
I then cut the track from the SDA and SCL lines on the back of the board. <see RTC Track CUTS>. There are via's at both ends of these tracks so if I want to restore thing later, I can run a jump from the respect via's.
Finally I connected the SDA and SCL line to the standard I2C. This could be done at pin 12 and 13 on the connector- but there are two via's close by as shown in the top side picture. <see RTC WIRES DRAWN and RTC WIRES>
I then can use the code that was contributed on the forum for the internal I2C board that was bought on EBay and used the PCF8563. It works well.
Also note that since I2C is multidrop, having one thing hanging on it doesn't really hurt anything as long as there is no address conflict.
Thanks to the group for all you sharing and I hope this will be enjoyed.
John Wettroth
jebz
Posted: 04:16am 29 Oct 2011
  jwettroth said  It works well.
Very well done!
sparkey
Posted: 06:00am 29 Oct 2011
does geoff`s firm 2.7a work with this rtc mod as i have 2 complete kitsets for the sm1 boards...regards sparkey...///
jwettroth
Posted: 01:12pm 30 Oct 2011
@Sparkey- I see no reason why not assuming that your boards are the same as production SM1's as far as the schematic goes. I think these were slightly different mechanically. When you've finished with my mod, you'll simply have an 8563 RTC connected to the standard Maximite I2C port. I'm using it with 2.7a. The software required is just a basic program in MMBASIC and I believe was working with V2.6 or earlier.
To be more explicit about the basic code to use. The following code was written by jman. There is a 5 page thread that started on 17 October called "Internal RTC". The first mod is for a Dallas/Maxim DS1307 RTC that is not compatible but similar. The thread continues and covers a small board which uses the 8563 that people bought on Ebay and installed internally. jman revised his code to use the 8563 and posted his code. I've included it below to keep it simple.
8563 Clock code by jman- works with this mod.
2011-10-30_230759_2011-07-28_171338_PCF8563.zip
Its quite well done.
I hope this clears things up.
John Wettroth
sparkey
Posted: 11:30pm 30 Oct 2011
my question is simple that buy doing your mod an adding the components will the rtc after setting the time ..that the rtc will work with on its own then...regards sparkey...///
VK6MRG
Posted: 01:01am 31 Oct 2011
http://www.thebackshed.com/forum/forum_posts.asp?TID=3790&PN =2
This is the link to the RTC topic.Edited by VK6MRG 2011-11-01
sparkey
Posted: 02:06am 31 Oct 2011
thanks matthew...///...///
well the origanal pins from the chip get taken out to the "U11" sckt on the ev board
and from what you are suggesting that the origanal cct is wrong there for i think it may be a simple matter of removing of the two resistors on the ev board and running the two wires from the smi board where u have suggested to the ev board where your wiring goes and just adding the 5v line and joining the earths together ...i think thats it Edited by sparkey 2011-11-01
sparkey
Posted: 01:29pm 31 Oct 2011
i dont get it once the "rtc": has been installed ...dont you just enter the date and time from the command li8ne....or does your program acess the "rtc"chip i dont want to have to include these programs into my other programs just to get the time or is this for display purposes...um a little confused...///...///
Greg Fordyce
Posted: 03:33pm 31 Oct 2011
Hi Sparkey,
I haven't tried this yet, but in the Zip file a few posts up, use program wr8563.txt to set the time and date in the rtc chip. You should only have to do this once. Then whenever you power up the MM, run the read8563.txt to set the time and date in the MM. You should only need to do this when first powering up the MM. If you rename read8563.txt to autorun.bas and save it to the root directory of drive a: or b: then this will be done for you automatically on power up.
hth, Greg
sparkey
Posted: 03:49pm 31 Oct 2011
i am getting a error in line 446 says invalad date ...any help and iam also not shure whic wire joins on pin 3 and four time clock is not keeping time and i dont know the correct value for c-15 i think its 100n but not shure sm1 cct does not say its value and i am also running the rtc on the sm1 board i have isolated the cct as fas i know but also getting "nack" error dont know what this means...///
i am running a ev board if you check my "spot u can see what i have done...///Edited by sparkey 2011-11-02
VK6MRG
Posted: 04:05pm 31 Oct 2011
Just a quick question to all the guys running a RTC.
With the RTC connected to the I/O pins of the Maximite, and assuming I run the read8563.bas code in the AUTORUN.BAS, can the I/O pins that are used on the RTC be assigned to whatever in my code to run as digital in's or out's?
Or once I have elected to use the RTC I have to give up these two I/O pins?
sparkey
Posted: 04:08pm 31 Oct 2011
i think u would because they are being used it makes sense that you would have to give them up to the rtc but dont quote me on this ...///
VK6MRG
Posted: 04:59pm 31 Oct 2011
OK. I'm getting an error.
Error line 445: Invalid time
VK6MRG
Posted: 05:12pm 31 Oct 2011
OK. I'm now able to set the time and date to the RTC!
BUT, when I run the read.bas in my autorun to set the time and date, I get the following error.
Error line 446:Invalid date
Hmmmm, what's going on?
VK6MRG
Posted: 05:22pm 31 Oct 2011
OK!
I finished reading the thread and found the problem!
The RTC is working A OK!
Maybe next time I will read ALL of the info and not just skim over everything.
jman
Posted: 06:18pm 31 Oct 2011
  VK6MRG said   Just a quick question to all the guys running a RTC.
The RTC use's I2C
So once you have the correct time and date and if you no longer need I2C
issue a I2CSDIS command and this will allow you to use the pins for normal I/O
but dont forget they are pulled high by the 2 resistors
Jman
Talbit
Posted: 06:44pm 31 Oct 2011
A lot of great work has been going on with this clock so here's a challenge for the interested...
Is it possible to get the time from a GPS (I've done this with my GPS clock a few posts back - See my post on 26 Sept "GPS Clock") and get it to set the clock?
My idea is you read the NMEA string from the GPS through a comm port and parse the time and date. This I’ve done. Then you can manipulate the data to fit a particular format. Then the challenge is to feed it into the clock. You only need to do this once – or occasionally to reset the clock.
And… Is it possible to get the clock to increment on an external pulse like a PPS from the GPS?
And one more… Is it possible to read the clock so that it can be displayed on the LCD?
Talbit
Edited by Talbit 2011-11-02
Talbit
sparkey
Posted: 07:36pm 31 Oct 2011
i am still getting the error 446 line in valid date ..but when i run the write prog it comes up ok ..have tried setting the time manuly and dat but still comes up with the same error ...thanks...///
sparkey
Posted: 08:56pm 31 Oct 2011
i finally cracked it ...///...///
VK6MRG
Posted: 08:11am 01 Nov 2011
OK. Here is the working code for the RTC in an Altronics Maximite using an eBay RTC (8563) that has been mounted directly onto the ICSP header with the two tracks to the PIC32 cut and two wire links to I/O pins 12 and 13 (SDA & SCL).
The time and date needs to be set first using DATE$="DD/MM/YYYY" and TIME$="HH:MM:SS"
Use the PRINT DATE$ and PRINT TIME$ commands to confirm the time and date.
Next run the WR8563.TXT file. I renamed the file to SETTIME.BAS and I have it below.
600 ' Get time from time$ and date$
610 tempdec = VAL(LEFT$(TIME$, 2))
615 GOSUB 1100
617 hours = hex
620 tempdec = VAL(MID$(TIME$, 4, 2))
625 GOSUB 1100
627 minutes = hex
630 tempdec = VAL(RIGHT$(TIME$, 2))
635 GOSUB 1100
637 seconds = hex
640 tempdec = VAL(LEFT$(DATE$, 2))
645 GOSUB 1100
647 day = hex
650 tempdec = VAL(MID$(DATE$, 4, 2))
655 GOSUB 1100
657 month = hex
660 tempdec = (VAL(RIGHT$(DATE$, 4)) - 2000)
665 GOSUB 1100
667 year = hex
670 ' rtcctrl = &h10
680 rtcwday= &h1
690 ' Write Time to RTC
700 i2caddr = &h51 ' PCF8563 I2C address
710 I2CEN 100,100 ' Enable I2C
720 I2CSEND i2caddr, 0, 1 , &h0
725 I2CSEND i2caddr, 0, 10, 0, 0, 0, seconds, minutes, hours, day, rtcwday, mont
h, year
730 I2CDIS
770 ? "0=ok 1=nack 2=timeout"; MM.I2C
780 END
1100 ' Convert to Hex
1110 hex = FIX(tempdec / 10) * 16
1120 hex = hex OR ((tempdec / 10) - (FIX(tempdec / 10))) * 10
1140 RETURN
This includes the changes mentioned in another topic!
Once this has been done, turn off and on the Maximite. Check the time and date as before. (PRINT DATE$ and PRINT TIME$ commands to confirm the time and date).
If it shows the correct time and date, you're good to go. If you want to have the correct time and date set and shown on startup, you will need to add some extras to your AUTORUN.BAS file. Here is mine as an example.
10 ' Sample AUTORUN.BAS file
20 '
30 ' set the programmable function keys
40 OPTION F1 "RUN"+CHR$(13)
50 OPTION F2 "SAVE"+CHR$(13)
60 OPTION F3 "LIST"+CHR$(13)
70 OPTION F4 "EDIT "
80 OPTION F5 "RUN "+CHR$(34)
90 OPTION F6 "SAVE "+CHR$(34)
100 OPTION F7 "LIST "
110 OPTION F8 "PRINT "
120 OPTION F9 "IF "
130 OPTION F10 "ENDIF"
140 OPTION F11 "FOR "
150 OPTION F12 "NEXT "
160 '
170 ' set the prompt to show the current drive
180 OPTION PROMPT MM.DRIVE$ + "\>"
190 RUN "readtime.bas"
200 'END OR NEW, BUT THIS NEEDS TO BE ADDED TO THE READTIME.BAS FILE
I have renamed the READ8563.TXT to READTIME.BAS so you can follow what is going on.
The working READ8563.TXT code for my Maximite is below.
100 ' I2C RTC based On PCF8563 Secs,Mins,Hours,Day,Date,Month,Year
200 DIM RTCbuff(255)
220 i2caddr = &h51 ' PCF8563 I2C address
250 I2CEN 100,100 ' Enable I2C
260 I2CRCV i2caddr, 0, 7, RTCbuff(0), 1, 2
265 I2CDIS
270 BCDTEMP = RTCBuff(0) AND &H7F ' Mask unwanted bits
280 GOSUB 1000
290 sec$ = STR$(decimal)
295 BCDTEMP = RTCBuff(1) AND &H7F ' Mask unwanted bits
300 GOSUB 1000
305 min$ = STR$(decimal)
310 BCDTEMP = RTCBuff(2) AND &H3f ' Mask unwanted bits
315 GOSUB 1000
320 hours$ = STR$(decimal)
325 BCDTEMP = RTCBuff(3) AND &H3f ' Mask unwanted bits
330 GOSUB 1000
340 day$ = STR$(decimal)
350 BCDTEMP = RTCBuff(5) AND &h1F ' Mask unwanted bits
360 GOSUB 1000
370 month$ = STR$(decimal)
380 bcdtemp = rtcbuff(6)
390 GOSUB 1000
400 year$ = STR$(decimal + 2000 )
440 t$ = hours$+":"+min$+":"+sec$
442 D$ = day$+"/"+month$+"/"+year$
445 TIME$ = T$
446 DATE$ = D$
450 ? "Time has been set to ";TIME$
460 ?"Date has been set to ";DATE$
500 END
1000 ' Convert to Decimal
1010 Decimal = FIX(BCDTemp / 16) * 10
1020 Decimal = Decimal + (BCDTEMP AND &hF)
1030 RETURN
I have the AUTORUN.BAS and READTIME.BAS in my A: drive.
And this is what it looks like.
Hope this helps.
Edited by VK6MRG 2011-11-02
     Page 1 of 4
