Local Time 22:15 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Blank Maximite PCB
elproducts
Posted: 02:49pm 26 Oct 2011
Somebody was selling blank Maximite PCBs on EBAY but I can't find the post or the listing on EBAY.
Whoever that was (sorry I cannot remember) do you have any left?
www.elproducts.com
crackerjack
Posted: 07:24pm 26 Oct 2011
The seller I believe was "trippyben". See this post http://www.thebackshed.com/forum/forum_posts.asp?TID=3631
Cheers.
trippyben
Posted: 09:15am 27 Oct 2011
Yep, that was me. I have 9 lest at $10 each + postage. Send me a PM to find out more.
Ben
cmichaelcouch
Posted: 06:36pm 28 Oct 2011
Anybody interested in assembling these Maximites or Mini Maximites?
aargee
Posted: 12:37am 29 Oct 2011
I've put together two original Maximites and a UBW32 (with insy winsy SMD components) using blank PCBs by hand soldering (including the PIC chips) - they all worked out fine. I've got another UBW32 to build and was thinking of using the toaster oven/ solder paste method.
The UBW boards I bought are from a batch that Haiqu got made, are pre-tinned with just enough solder that I think the PIC may reflow with just flux and no solder paste, that's how it worked when I hand soldered the other one.
I did read your piece on the toaster oven matter, Geoff, but curiosity - I just to see what it's like.
KMart has a cheap ($35) toaster oven and so does Rays Music in Chicago.
- Rob.
Posted: 01:53am 29 Oct 2011
I have had reasonable success with a toaster oven (a $50 cheapie from KMart).
I only use it to do the resistors and caps as it is easy to put a blob of solder paste on the pads, then stick the components onto the paste. This method is great as it does all the components in one shot, much quicker than soldering each component by hand.
I could never get it to reliably solder ICs as the paste would blob creating shorts between the pins. This is why I recommend to beginners that they should stick to hand soldering.
Using the toaster oven I put the thermocouple on the top of the board and watch the temperature, when it hits 215 degrees C I cut the power and immediately the temperature starts coasting down. I have also had success with a hot air tool, just wave it around and watch for when the solder melts. It takes longer but it still works.
I found that it was a great help to practice on plenty of discarded boards. That way you can get the process right before messing with a valuable PCB.
