Local Time 22:01 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Strings and Quotes
crackerjack
Posted: 12:51am 15 Oct 2011
I'm unsure if this has been noticed or mentioned before, but it seems that MMBasic doesn't require end quotes on strings. This is odd, but advantageous if you want to save a byte here and there and a keystroke or two. Newline seems to suffice to terminate the string. Try these:
[code]
load "myprog.bas
...or...
A$ = "test
? A$
[/code]Edited by crackerjack 2011-10-16
Greg Fordyce
Posted: 09:07am 15 Oct 2011
I have noticed this as well, but it will only save you a few keystrokes. MMBasic will add the end quotes to a program listing. Try this,
> 10 print "Hello
> list
10 PRINT "Hello"
aargee
Posted: 11:00am 15 Oct 2011
That was actually part of many of the original Basic implementations. I clearly remember programming this way in the early '80s and I've never used an end quote with the MM.Edited by aargee 2011-10-16
crackerjack
Posted: 12:18am 16 Oct 2011
Just look out for strange and odd behaviour if you have multi-line statements such as:
[code]
10 A$ = "Foo : B$ = "Bar
[/code]
A$ will have a value of Foo : B$ = and B$ will be uninitialised and empty. MMBasic will not add end-quotes.
