Local Time 22:15 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : maximite terminal
palcal
Posted: 12:30am 12 Oct 2011
I want to use my Maximite with my laptop as the terminal. Downloaded Terraterm but is a very old program and does not support USB. Anyone know of any free terminal emulator software.
Paul.
Ray B
Posted: 12:47am 12 Oct 2011
Download TeraTerm then this works from your USB port direct to the MM. TeraTerm is supported by a scripting language that allows you to do a range of smart things.
http://ttssh2.sourceforge.jp/
You will need to configure as a serial port
Enjoy your MM
RayB from Perth WA
BobDevries
Posted: 12:57am 12 Oct 2011
Terra Term V4.70 does support USB connections.
Your Maximite will show up as a COM port. Check in the Hardware manager to see which com port is the Maximite.
Bob Devries
Dalby, QLD, Australia
We could probably use a set of Terraterm set up instructions, with screen shots. Anyone up to it? I'll be happy to put it on the site as a page we can refer people to in the future, and see if Don wants to add it to his Maximite page as well.
donmck
Posted: 01:10am 12 Oct 2011
  Gizmo said   We could probably use a set of Terraterm set up instructions, with screen shots. Anyone up to it? I'll be happy to put it on the site as a page we can refer people to in the future, and see if Don wants to add it to his Maximite page as well.
More than happy to, of course Glenn.
Anything that will help in the way of good info.
Cheers Don...
https://www.dontronics.com
donmck
Posted: 04:29am 02 Nov 2011
Cheers Don...
Just adding to this, I have a user that is having trouble getting PUTTY to work.
Is there a set of instructions for this currently on the forum?
Cheers Don...
sparkey
Posted: 05:00am 02 Nov 2011
i dont have any trouble with using hyper terminal but then there may be tasks that i have not asked from it ...///...///
