Forum Index : Microcontroller and PC projects : Oh My God Silchip
| sparkey Senior Member Joined: 15/06/2011 Location: AustraliaPosts: 819 |
has any body seriously seen flames comming from the blown driver powered by a 20000 watt amp from iron madion who if i am correctyly spoken hold the world deffeness conentation to ...my day i have never seen flames comming out of the driverers walof sh%%%".... sorry but had to have my say and i have blown my fair share but i have never seen fire molten steel yes but never fire .... technicians do it with least resistance |
Hi Sparky I take it you are refering to the picture of the speaker on fire on the front of this months edition of Silicon Chip magazine. Yes I agree, its highly unlikely they can catch fire, the voice coil will burn out but wont generate anough heat to start a full on fire in the speaker cone. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
regards sparkey i have seen many coils reduced to molten larva but on fire well will some body steer me right well i went to thw world slavery tour of iron maden must have been 100,000 valves burning their hearts out i stll have my ears rining...regards sparkey when it comes to reality i`m sorry but i just got my issaue and could not help my self...regards spaarkey ///long live and phrospher...////... technicians do it with least resistance |
hey glenn long live the sounds of hell just let this tropic slip through the wavelenth its not important but i had to say something about this topic if you had 20000 volts at hand and may be 100 a/h you may find fire but i seriously doubt it speakers on fire well have you got a three phase amp...regards sparky...end of topic scrub it if u wish .... technicians do it with least resistance |
Worm![]() Newbie Joined: 30/06/2011 Location: New ZealandPosts: 38 |
Yep, they do catch on fire. Try putting 230 volts across them. Some cones just jump out and seize while others catch on fire. Try it sparkey.
Kevin There's no such thing as a free lunch. |
i have a great deal of "a/h/rs" on hand and i am not about to put my polk audio series 4800`s to the test ...regards sparkey ... technicians do it with least resistance |
ok who`s gunna set fire to my kevlar woven woffers....regards sparkey ..maybe you could use a miximite explosion ..."maximite is higly explosive..." regards sparkey technicians do it with least resistance |
Hi sparkey, I would love to set fire to your kevlar woven woffers. Two problems. 1. you live too far away and 2. Im pretty sure kevlar does not burn. In saying that, maybe we could douse your speakers with petrol. Hope that helps. Kevin There's no such thing as a free lunch. |
| seco61 Senior Member Joined: 15/06/2011 Location: AustraliaPosts: 205 |
Hi All. If you read the article it mentions (somewhere) that the speakers did not catch fire during their test - but definitely burnt out the coil. It also mentions that to create the picture they used a gas torch (or lighter? I forget which) to ignite the speaker cone.... Regards Gerard (vk3cg/vk3grs) |
ok i`ll byte i will go and get a 10 inch driver and directly connect it too my 36 volt 300 a/hr power supply and lets just see if i can get fire out of it i seriously dought it i will wire it through my "variac" as to slowly turn upthe power and sit here and if the cone has not thrown its self six foot out of the souurroundings and the voice coil is not molten metal arround the magnet i`ll just sit here in utter dissapointment...regards sparkey....//// technicians do it with least resistance |
| Talbit Senior Member Joined: 07/06/2011 Location: AustraliaPosts: 210 |
You'll need more than 36 volts Talbit Talbit |
| VK4AYQ Guru Joined: 02/12/2009 Location: AustraliaPosts: 2539 |
Hi All Anything can and will burn if Murphy is active and close by. In my little escapade recently one of my speaker boxes went up started by my battery charger, all I had left was a heap of molten metal from the speaker frames. All the best Bob Foolin Around |
