Local Time 21:48 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Hardware question
Buchan
Posted: 05:09am 01 Oct 2011
Great project Geoff. I am working on several projects using this magic machine, mostly using GPS units, but I have a few little questions that some may assist me with.
1. In one of the Silicon Chip articles, a picture shows connection leads from the Maximite to a 'breadboard'. Where can we get these leads from?
2. One of the articles mentions tying any unused I/O pins to either Hi or Low. Is this essential?
Doug, The farmer
sparkey
Posted: 05:23am 01 Oct 2011
dear doug the jumper leads that you are refering to can be obtained from dontronics....just go to one of dons threads and look up the dontronics shop there are several lead sets to chose from
generally it is common when using a i/o pin to tie it well basically low and a value between 1 and ten k-ohms usully does the trick to hold the pin at a constant usully tied to ground ...u dont have to tie all the pins to ground and depending on your app lication ..hope this helps regards sparkey and welcome to the "shed" ....Edited by sparkey 2011-10-02
sparkey
Posted: 05:32am 01 Oct 2011
also if you are looking for a bread board expander kit ...might i recomend getting one from hamfeild " thay come with male jumper leads the board is easy to assemble and i found it to be just a "treat " to work with just look for a thread posted by "rohan " that should give you some ideas or go to "www.hamfield.com"you should see many of the add on kits there as well "dontronics" has kits for the maxi as well ...regards sparkey...
Buchan
Posted: 05:34am 01 Oct 2011
Thanks Sparkey.
T'was what I was thinking about tying the pins. I guess it's to stop any possibility of an emf spike killing parts of the chip.
I went to Altronics and Jaycar recently (about 450km from home) but they had nothing of the type. Our local DSE is now looking more and more like a H/N (brand name) retail, the only parts they had was fuses. So sad.
I'll try Don and see what he can supply.
Thanks again for the answer.
Doug. The Farmer
sparkey
Posted: 05:38am 01 Oct 2011
any other questions you hav just post them on your thread and i will keep an eye out for you ...regards sparkey
sparkey
Posted: 05:50am 01 Oct 2011
if your having trouble finding the leads goto" the maximite computer then scroll down the page the lead sets arre about 3/4 of the way down ...regards sparkey
also check out geoffs website there yo will find an abundance of good and helpfull info ..cheers ...i am not into footy...Edited by sparkey 2011-10-02
Buchan
Posted: 06:09am 01 Oct 2011
G'Day Sparkey,
Football's Not my game. Someone will win, but hope Casey Stoner wins the MotoGP.
Am putting order into dontronics for leads, thanks for the 'lead'.
Just finished building our mud brick house, so celebrating that.
Doug. The farmer.
donmck
Posted: 08:17am 01 Oct 2011
Doug. The farmer.
In a former life, I was an electrician, and wired many a mud brick house. Lots of fun trying to get wiring and fittings to stay put on the bricks, especially an old home where you didn't have channels for cable runs in place.
Cheers Don...
https://www.dontronics.com
sparkey
Posted: 11:39am 01 Oct 2011
also would like to add "there was some posts about g.p.s`s stuff...have a look round the posts //regards sparkey....
and as for dick smith ..well forget about spare parts the have gone out of that stuff now ...it sholdent be that way but thats progress ....Edited by sparkey 2011-10-02
aargee
Posted: 11:57pm 01 Oct 2011
Doug,
Would love to build a mud brick house, planning that or a hay bale place in our ten year plan. First would be to build an electronics workshop as a trial...
How did it go?
- Rob.
Buchan
Posted: 06:45am 02 Oct 2011
Rob,
Maybe we could start a new forum for Mud Brick etc. type houses. Would be glad to discuss & upload photo's, or email me. This house was to be our music studio, but after the drought no money left to build the 'real' house.
Don, wired all myself under lic'd supervision (my sparkey permit expired). Order for jumpers is with the cheque.
Thank's Sparkey for the info regarding GPS's. The chips I am using will be integrated with the Maximite in a very rural, remote, dusty and vibrating setting. Just waiting to get the parts to make the 12v vehicle P/S (much like Geoff's Car GPS) so nothing gets fried.
The programming is based on 2.6 for the com port, but there is also a lot of pc programs to make it all work.
Doug. The Farmer
thenuggetblock@avtiv8.net.au
Posted: 08:31am 02 Oct 2011
If I get enough interest I would be happy to add it. So long as members thinks there would be enough post activity to warrant it. Nothing worse than a subject area that nevers gets a post, like the EV section of the forum.
Would need a scope of discussion. Like building, renovating, plumbing, insulation, etc.
vasi
Posted: 09:43am 02 Oct 2011
I would like that. It was a time when acquiring a lot of plans, images and web addresses from the web regarding to subject. It would be great.
An EV project is very expensive. Not anyone meet the requirements (a lot of money and skills). Microcontrollers are for everyone. Edited by vasi 2011-10-03
Elvish name: Mablung Miriel
Beyound Arduino Lang
