Local Time 21:35 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Patch Leads
johnbig
Posted: 02:56am 26 Sep 2011
Does anyone know where to get patch leads, male to female, to use between the Maximite 26 pin plug and breadboard sockets as in the picture?
I wouldn't mind buying an assortment but I would also like to get the part numbers for the male and female ends to make my own as well.
Kind Regards
John Leate
Posted: 03:06am 26 Sep 2011
  johnbig said   Does anyone know where to get patch leads, male to female, to use between the Maximite 26 pin plug and breadboard sockets as in the picture?
Kind Regards
John Leate
Hi John,
I think Don has MALE-MALE and FEMALE-FEMALE types.
Your could join the two together and make a MALE-FEMALE type like you want.
Female
Male
Just search for wires on dontronics.com
jebz
Posted: 04:11am 26 Sep 2011
This kit from Hamfield is very good with the leads and breadboard included -
http://www.hamfield.com.au/prototype-board.htm
Posted: 10:58am 26 Sep 2011
The jumper leads that I used are 12cm long and have a male pin at one end and a female socket at the other. Mine came from SchmartBoard.com (part 920-0023-01) but you can also buy them from SparkFun.com or make up your own using a female socket (Jaycar HP1260) and pins taken from a header strip (Jaycar HM3211).
Ray B
Posted: 12:31pm 26 Sep 2011
ebay search the following
Solderless Breadboard Jumper Wire 70x Male 30x Female
cost about $8 out of China if you don't mind waiting 2 weeks - free postage
I'm very happy with what I got
RayB from Perth WA
