Local Time 21:35 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Can’t capture a BMP image.
aargee
Posted: 12:16am 20 Sep 2011
Geoff,
I can't seem to capture a BMP image with the SAVEBMP command. It reports that the file is already open (sorry, can't remember the exact text), even when I use different file names for the first time.
I've checked the syntax several times and it seems OK.
I'm using version 2.6 with Com. Port 1 running at 19k2 into a VGA monitor.
Can someone try it out and post the piece of code if it works?
Thanks,
Rob.
BobDevries
Posted: 12:31am 20 Sep 2011
Aargee,
I used this code snippet:
10 OPEN "COM1:19200" AS #5
20 CLS
30 CIRCLE(50,50),10
40 SAVEBMP"COMTEST"
50 CLOSE #5
That works fine, no errors.
Bob Devries
Dalby, QLD, Australia
aargee
Posted: 01:33am 20 Sep 2011
Aah, might have spotted the problem, I'm putting a space between SAVEBMP and "filename" (the manual shows a space as well?)
I'll give it a go when I get home tonight.
Thanks, Bob.
- Rob.
BobDevries
Posted: 02:25am 20 Sep 2011
Aargee,
I tried that with a space between SAVEBMP and the filename, but still no error.
Can you post some code to show what you're doing? Someone else may notice a flaw?
Bob Devries
aargee
Posted: 07:49am 20 Sep 2011
Hmm, I don't know if it is a bug, but I had the com port open as #1 and it errors.
If I use Com port as #5 all is well!?
The manual uses #1 as an example of Com port usage but it must interfere with the BMP storage routine.
Geoff - is it a bug?
- Rob.
ajkw
Posted: 08:22am 20 Sep 2011
opening the com port as #1 or #2 generates the file open error, #3 and #5 work ok on mine.
Anthony,
BobDevries
Posted: 08:48am 20 Sep 2011
I can confirm that problem. I changed my snippet to use #1, and kablooie!
Error line 40: File number is already open
In my view, any internal command (such as SAVEBMP) should not use a file number that's usable by user programmes.
My $0.02 + GST
Bob Devries
Posted: 01:15pm 20 Sep 2011
Ah, another bug found and squashed!
Thanks everyone, that was a subtle bug indeed.
The SAVEBMP does a scan of the file table to find a free file number... and got it wrong. I have fixed it and the fix will appear in the next version, until then the workaround is to avoid using the file numbers #1 or #2 if you are also using the SAVEBMP command.
This really illustrates how hard it is to test for bugs these days. The bug only occurred in rare circumstances and I never thought to test the command with a range of different file numbers open at the same time.
aargee
Posted: 08:49pm 20 Sep 2011
Thanks, Geoff, glad we could help !!
