Local Time 21:35 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Rudimentary Speed Test
crackerjack
Posted: 01:41pm 13 Sep 2011
I ran a very basic speed test against v2.5 and v2.6 as follows:
[code]
10 SETPIN 12, 9
20 PIN(12) = NOT PIN(12)
30 GOTO 20
[/code]
Not having the most sophisticated test lab, I then measured the output of pin 12 (which had a 1k pull-up) with the freq. meter mode of my mulitimeter.
The results? 4.64 kHz under V2.5; 5.97 kHz under V2.6 - about a 29% improvement in speed - pretty much what Geoff has stated for this version.
The value of the pull-up resistor will certainly affect the frequency, but I kept the value constant between tests.
If anybody knows of a better/easier/more reliable way of veryifing basic processing speed of the Maximite, I'd like to know about it. Also, using a method such as the above - what are your results? It may (or may not) be interesting.
Cheers, Lance.
Posted: 11:13pm 13 Sep 2011
  crackerjack said   I ran a very basic speed test against v2.5 and v2.6 as follows:
[code]
10 SETPIN 12, 9
30 GOTO 20
[/code]
Gday Lance,
What happens if you set as digital output? ie SETPIN 12, 8? Use 8 instead of 9.
Then you wont need the pullup..
regards,
mick
trippyben
Posted: 08:16am 14 Sep 2011
Can't see how your pull up resistor will have any effect on the frequency output by the pin? Sounds like a reasonable comparison to me.
crackerjack
Posted: 11:20am 14 Sep 2011
Mick - Good suggestion - the only reason I used Open Collector was because I was trying to minimise the number of lines of code per "cycle". It turns out, as per your suggestion (and the following code):
[code]
10 SETPIN 12, 8
20 PIN(12) = 1 : PIN(12) = 0
30 GOTO 20
[/code]
...that the overall cycle speed increases quite substantially:
v2.5 = 8.20 kHz
v2.6 = 10.58 kHz
Again, 29% faster.
Trippyben - I'm not a hardware guru (much to learn in that space), but I was under the impression that rise times are slower with higher value pull-ups - maybe this only really applies in a bus situation with many devices, stray capacitance, etc. (see here). Under the section Different Voltage Interfacing, it states "Smaller values offer faster switching times at the price of higher current consumption."
I have not experimented with resistor values like 100k vs 1k, but I'll give it a go.
Thanks for your interest and comments.
Cheers, Lance.
trippyben
Posted: 11:24am 14 Sep 2011
Lance, while it is true that the pullup resistor will affect the rise/fall times, it won't affect the overall frequency of the output.
The change in rise/fall times will only serve to 'round off' the shape of the square wave as they increase, the base frequency will remain the same. If you've got a CRO, have a look with a couple of different pull-up values. You should see the shape of the wave change, but the overall period (The time for a compete cycle) should stay the same.
Ben.
crackerjack
Posted: 11:38am 14 Sep 2011
Thanks Ben - that makes sense. I have my eye on a 'scope and will be getting an early Chrissy present I think. I know these are simple experiments, but it is certainly teaching me some things. As an example the following minor mods to the code have had quite a big impact:
[code]
10 SETPIN 12, 8
15 DO
30 LOOP
[/code]
This increases the frequency to 12.83 KHz (v2.6). That shows me that using a LOOP over a GOTO for the main loop of a program may potentially make a big difference to execution speeds. In this case, another 21%. Overall, changing the firmware and the code structure (yet still achieving the same thing), the code execution speed has increased of 2.75 times.
Pretty interesting I think - especially the DO...LOOP over the GOTO.
Cheers.
VK6MRG
Posted: 11:43am 14 Sep 2011
This is the speed test we used before.
http://www.thebackshed.com/forum/forum_posts.asp?TID=3667&PN =11
Posted: 11:54pm 14 Sep 2011
  crackerjack said
[code]
10 SETPIN 12, 8
15 DO
30 LOOP
[/code]
Cheers.
Gday Lance,
What happens if you combine it all on one line?
ie.:
[code]
10 SETPIN 12, 8
15 DO : PIN(12) = 1 : PIN(12) = 0 : LOOP
[/code]
Not knowing much about do:loop I am not sure the 1 line will even be in syntax.
