Local Time 21:09 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : The start of something new.
VK6MRG
Posted: 03:47am 10 Sep 2011
I have been looking at designing my own Maximite. As i have stated many times now, I want an all singing, all dancing, Maximite compatible, single PCB, Microcomputer.
The trouble i have been having is with the PIC32 100 pin chip track breakout design. But thanks to Micro Chip I have found a solution!
Ma320003
Now I have to start the real task of designing the layout of all the I/O options. (this may take me a while)
Edited by VK6MRG 2011-09-11
sparkey
Posted: 04:19am 10 Sep 2011
here here sparkey and while your at it lets go the hole cuboodle run at 120 MHz
Dave Everett
Posted: 09:35am 11 Sep 2011
I was looking at that too, but $60 for the usb interface? Outrageous. Luckily that is unnecessary to develop code.
Dave Everett
vasi
Posted: 12:30am 12 Sep 2011
  VK6MRG said   I have been looking at designing my own Maximite. As i have stated many times now, I want an all singing, all dancing, Maximite compatible, single PCB, Microcomputer.
Better save for a Chipkit MAX32 as you have already a functional and tested microcontroller with all the basic circuitry and sockets for all the I/O pins (plus, some protection on analog inputs against accidental 5Vcc). It require a modified version of Geoff's MMBasic but you will do that anyway. The board is nice and your shield will enrich it.
It use a serial bootloader but that may be on your advantage as you will obtain a faster Basic interpreter - no need to keep the USB awake, the FTDI chip is doing that for you. No USB firmware inside the engine, then more space for other things. But you can add it of course, as Basic language feature (that is better).
The advantage of having the other peripherals on a shield is that you can build it in a hurry, with what you have at hand, and changing it later with a better looking shield (which you can sell to anyone).
Vasi
Elvish name: Mablung Miriel
Beyound Arduino Lang
elproducts
Posted: 02:06am 14 Sep 2011
Vasi,
Has someone developed a Maximite version for the chipKIT that is available for download?
www.elproducts.com
vasi
Posted: 06:01am 14 Sep 2011
Ken Segler have a port for his Max32 board but the .hex file he posted is not downloadable by the avrdude who will crash. Right now he is working for Don's boards but when he will have enough time, he will post the complete sources as promised.
I personally tried to compile from a mix of sources for original Maximite and Max32 boards, trying to complete the missing files from Ken's archives. All trials ended in a non-uploadable firmware, causing avrdude to crash but last time I got an uploadable and workable (up to a point) variant which use UART2 as console (Ken's work). I guess switching to UART1 does not consist in only changing a number, we must change also the original pin usage to free the UART1... but I have also an error in the sources because you can write a program using numbers as labels but you can't execute any command in immediate mode.
I didn't investigated further because I have another project to finish but when I will return to this, I will use MPIDE to rewrite the firmware from scratch with a complete MAX32 pin assignment (I intend to continue what Geoff started with that file where you have aliases for your pins, making the firmware portable). Unless I will have Ken's complete and compilable sources to start with from inside MPLAB X...
VasiEdited by vasi 2011-09-15
haiqu
Posted: 09:13am 14 Sep 2011
Vasi,
I'm sticking with MPLAB 8.70 for now. MPLAB X seems to make very large binary files.
Rob
unzip, strip, touch, finger, grep, mount, fsck, more, yes, fsck, fsck, fsck, umount, sleep
elproducts
Posted: 11:32am 14 Sep 2011
Thanks Vasi.
I really just need the .hex file as I can flash it via PICkit 3 rather than avrdude.
Getting the full source would be excellent also.
I look forward to Ken's release.
Rob,
MPLABX uses the same compilers as MPLAB 8.7x so I don't understand why you would see larger binary files with a different IDE?
www.elproducts.com
vasi
Posted: 12:14pm 14 Sep 2011
Hi elproducts,
Here (at the end of article) is Ken's work, .hex and sources.
Rob, thanks for advice.
Vasi
vasi
Posted: 08:53pm 14 Sep 2011
BTW, the Microchip compilers we install and use along MPLAB classic or X, come in Lite version. For Windows you have the option to use a serial for the commercial part but in Linux I think you don't have that option (didn't paid enough attention)? Maybe we have Linux compilers without limitations?
Anyway, what I want to say is that usually we have just the Lite version for free and the compiler from MPIDE come without restrictions and produce full optimized code. I am right? Or that compiler have also a limit of 1000 cycles of compilation ? kidding...
If is true that MPIDE use a non-crippled compiler then, why not using it? Or, what is the reason or the logic Microchip continue to offer crippled versions of their compilers?
Anybody knows something about that?
Vasi
Posted: 10:19pm 14 Sep 2011
The MPLAB C32 compiler will install as a trial version and has no restrictions other than a time limit of (I think) 60 days. After the time limit it will turn into the Lite version which has two limitations; a max optimisation level of 1 and no 16 bit code. At any time you can enter a serial number that will convert it to the full version without restrictions.
As far as I know this behaviour is the same regardless of the version or type of IDE used.
vasi
Posted: 10:32pm 14 Sep 2011
  Geoffg said   The MPLAB C32 compiler will install as a trial version and has no restrictions other than a time limit of (I think) 60 days. After the time limit it will turn into the Lite version which has two limitations; a max optimisation level of 1 and no 16 bit code. At any time you can enter a serial number that will convert it to the full version without restrictions.
Hi Geoff,
Thanks, this is also what I know about MPLAB C32... what do you know about the compiler which come with the MPIDE?
Vasi
vasi
Posted: 10:36pm 14 Sep 2011
From the platforms.txt file from MPIDE package seems that the -O2 flag is used by default. It seems that is about a non-crippled compiler!
Vasi
vasi
Posted: 10:44pm 14 Sep 2011
In this thread you can see a different Microchip politic.
And bellow is the content of platforms.txt file:
[code] ############################################################ ##
pic32.recipe.c.o.pattern={0}{1}::{2}::{3}{4}::-DF_CPU={5}::- D{6}::-D{7}::{8}::{9}::{10}::-o::{11}
pic32.recipe.cpp.o.pattern={0}{1}::{2}::{3}{4}::-DF_CPU={5}: :-D{6}::-D{7}::{8}::{9}::{10}::-o::{11}
pic32.recipe.ar.pattern={0}{1}::{2}::{3}{4}::{5}
pic32.recipe.c.combine.pattern={0}{1}::{2}::{3}{4}::-o::{5}{ 6}.elf::{7}::{8}::-L{9}::-lm::-T::{10}/{11}
pic32.recipe.objcopy.eep.pattern={0}{1}::{2}::{3}.elf::{4}.e ep
pic32.recipe.objcopy.hex.pattern={0}{1}::{2}::{3}.elf
pic32.name=chipKit
#pic32.compiler.path=/opt/local/pic32/install-image/bin/
#pic32.compiler.path=/opt/pic32-tools/bin/
#pic32.compiler.path=C:\pic32-tools\bin\
#pic32.compiler.path=/opt/mac-pic32/bin/
pic32.compiler.c.cmd=pic32-gcc
pic32.compiler.path={0}/hardware/pic32/compiler/pic32-tools/ bin/
pic32.compiler.c.flags=-O2::-c::-mno-smart-io::-w::-ffunctio n-sections::-fdata-sections::-g::-mdebugger::-Wcast-align
pic32.compiler.cpp.cmd=pic32-g++
pic32.compiler.cpp.flags=-O2::-c::-mno-smart-io::-w::-fno-ex ceptions::-ffunction-sections::-fdata-sections::-g::-mdebugg er::-Wcast-align
pic32.compiler.S.flags=-O2::-g1::-c
pic32.compiler.ar.cmd=pic32-ar
pic32.compiler.ar.flags=rcs
pic32.compiler.objcopy.cmd=pic32-objcopy
pic32.compiler.objcopy.eep.flags=-O::ihex::-j::.eeprom::--se t-section-flags=.eeprom=alloc,load::--no-change-warnings::-- change-section-lma::.eeprom=0
pic32.compiler.elf2hex.flags=-a
pic32.compiler.elf2hex.cmd=pic32-bin2hex
#pic32.compiler.elf2hex.flags=-O::ihex::-R::.eeprom
#pic32.compiler.elf2hex.cmd=pic32-objcopy
pic32.compiler.c.elf.flags=-Os::-Wl,--gc-sections::-mdebugge r
pic32.compiler.c.elf.cmd=pic32-g++
pic32.compiler.cpudef=-mprocessor=
#pic32.compiler.ldflags=
pic32.compiler.ldscript=chipKIT-BL.ld
#pic32.compiler.includepath=/opt/local/pic32/install-image/p ic32mx/include
pic32.compiler.upload.cmd=
pic32.compiler.includepath={0}/hardware/pic32/compiler/pic32 -tools/pic32mx/include
pic32.compiler.upload.flags=
#pic32.library.path=./hardware/pic32/cores/pic32
pic32.ldscript=chipKIT-BL-mega.ld
pic32.library.core.path=./hardware/pic32/libraries
pic32.compiler.define=::
[/code]Edited by vasi 2011-09-16
Posted: 11:40pm 14 Sep 2011
  vasi said  Thanks, this is also what I know about MPLAB C32... what do you know about the compiler which come with the MPIDE?
Ah! Sorry, I was not following the thread as closely as I should have.
As far as I know it does have full optimisation but I have not played with it so you are ahead of me.
