Local Time 21:09 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MaxiMite Manual
Posted: 12:58am 04 Sep 2011
Hi All, (wink at Geoff)
With all these new versions of MMBasic popping up, has someone kept the manual up-to-date?
It isnt a lot of good having all these new commands and enhancements and not knowing the syntax or what pins they apply to..
Not meant to critisise but as constructive comment.
Posted: 01:55am 04 Sep 2011
Hi Mick,
I have fallen into the habit of releasing a new version of the manual with each non test release. The version numbers match so MMBasic Ver 2.5 also had a new version of the manual (also Ver 2.5). Same with the source.
For each test release (with an alpha suffix. eg, 2.5E) I usually provide some notes on this forum or a README as it is much faster than preparing the full documentation.
As I seemed to have got most of the bugs with 2.5E I should be able to turn that into Ver 2.6 (with manual) in a few days or so.
GeoffEdited by Geoffg 2011-09-05
Posted: 04:45am 04 Sep 2011
Makes sense Geoff, I havent seen any manuals since the original one.. sample code would always be a good addition for every command ... espically so for `non standard basic' commands.
Where is the correct link for the latest manual?
regards,
mik
Posted: 05:02am 04 Sep 2011
The latest one is always in my download section: http://geoffg.net/maximite.html#Downloads
Lately I have been also including the manual in each upgrade zip.
crackerjack
Posted: 07:21am 04 Sep 2011
How useful for newbs (like myself) would it be if we in this forum could come up with a library of example code showing the usage of each of the keywords, features etc. with circuits? I would be willing to help out if we can agree on a format and first cab off the rank w.r.t an example. I may have a crack at a very first "Flash an LED, Debounce a button press" example...
