Forum Index : Microcontroller and PC projects : PAL/NTSC
| Page 1 of 4 |
donmck![]() Guru Joined: 09/06/2011 Location: AustraliaPosts: 1314 |
Went and paid a visit to the thread I started on the piclist about the Maximite, and noticed this question posed: [code] by David Bley Aug 21, 2011; I don't know much about video displays. Has anyone got a code/hardware mod for Maximite to support composite video for NTSC? Just curious. I think that Maximite is cool. Does anyone remember how much of a productivity boost it was to go from a typewriter to a word processor? [/code] I know I have it as Wish List 25, but I am wondering if any of our US Maxiteers have marched forward with this one yet. Cheers Don... https://www.dontronics.com |
I'm probably wrong but isn't the differences between PAL and NTSC, apart from the native TV resolution for the country, just the way the colour information is processed? With its B&W image the Maximite should be OK on a PAL or NTSC screen. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
| sparkey Senior Member Joined: 15/06/2011 Location: AustraliaPosts: 819 |
hey don is that program that you just got hold of for the lcd sheild on your site under the ftp stuff...regards.. technicians do it with least resistance |
I guess you mean this one: Data and Schematics and all other relevant files are available from: http://www.themaximitecomputer.com/max/Programs/ Then Select Hardware, then Dontronics, then LCD You will find the details there to be able to convert this LCD to operate on 3.3V A/D for the press button switches, so that it can be used on a Maximite Computer System. This conversion and code, was done by my good friend Mick Gulovsen. Cheers Don... https://www.dontronics.com |
haiqu![]() Senior Member Joined: 30/07/2011 Location: AustraliaPosts: 152 |
Quite a few differences. Frame rates, number of lines per frame, etc. Expect to get requests for SECAM too, there is one of these on order in Russia and the French use it as well. Shouldn't be much of a change anyhow, and I suspect most people will use an old VGA monitor. Rob unzip, strip, touch, finger, grep, mount, fsck, more, yes, fsck, fsck, fsck, umount, sleep |
i argree ssurely peop`s will be better off using a old monitor rather than tie up their tv sets even though they could run the rca video/pal to most or their sets any way ...regards ...even wiriring a s-video lead to fit teir sets would not be difficult ,, technicians do it with least resistance |
it would be simpler if sombody just made an adaptor plug on a board coverting the vga too s-video....sparkey ..i am loking at this one my self dont think it will be much of a challenge.../// technicians do it with least resistance |
just looking at "wes components " in asfeild n.s.w." they have hundreds of different adaptors including pal to s-video "02_97979866" technicians do it with least resistance |
Some one in this Forum posted a story with picture on just this. He had a VGA to video adapter, I think to basically save diving inside the box, and wiring to the header. So, I wonder about the discrete differences, as mentioned earlier in this thread. Video isn't my thing. Cheers Don... https://www.dontronics.com |
YES THAT MAY HAVE BEEN ME DON I HAVE A VGA COVERTER IT HAS THREE INPUTS :VGA FROM MONITOR :S=VIDEO :PAL RCA :OUTPUTS TO A VGA MONITOR HAS A REMOTE CONTROL ... and i think that the video game shops sell a converter unit i do rember buying one for a customer who needed to attach her artari to her tele vision...regards technicians do it with least resistance |
| aargee Senior Member Joined: 21/08/2008 Location: AustraliaPosts: 255 |
I made that little dongle (see here) that hangs off the VGA port and is wired to an RCA connector. If you look at the circuit, the composite video signal appears as part of the VGA signal on the connector. - Rob. For crying out loud, all I wanted to do was flash this blasted LED. |
Oh, of course, silly Donnie.
Thanks Rob. Perhaps a Basic command to toggle. So we need look up tables of some sort, for NTSC and SECAM operation. I know most people don't use it, in fact I think Rob is the only one to date that has indicated he has, but obviously it is a concern for many. Cheers Don... https://www.dontronics.com |
This NTSC thing keeps popping up, and I am wondering if we can revisit it, and get the problem solved for all non-Australian users. Would it be possible to poke the NTSC values into the correct memory locations, so it can be tested by a reasonable number of potential users? I am open to any suggestions. Cheers Don... https://www.dontronics.com |
| ksdesigns Senior Member Joined: 25/06/2011 Location: United StatesPosts: 143 |
I made a version for some one on here for NTSC didn't hear back if it worked for him ok worked on my monitor fine but you only get 16 lines instead of 18 we have less scan lines
Here's the HEX if anyone wants to test it ken |
I have had far from ideal results using the numbers I was given and recompiling the firmware. Micromites and Maximites! - Beginning Maximite |
Your hex file does the very same thing as the image I just posted. Micromites and Maximites! - Beginning Maximite |
I do have a new tv/monitor that will lock on to this version of NTSC, but then it will lock on to PAL, too. Micromites and Maximites! - Beginning Maximite |
does this monitor have any adjustments ? vert/horz ? would like to know how much you have to tweek it to lock ken |
The pictured monitor has vertical hold, no horizontal hold adjustment. Monitor #2 will display an ntsc signal from another source, but displays MM video (still scrambled) for a second before giving up. My modulator input (ntsc input into all of the connected house tvs) shows nothing. Direct into a modern LCD TV works. (So does PAL) I wonder if the signal voltage is too low, or the sync signals (blacker-than-black) are too high. Micromites and Maximites! - Beginning Maximite |
Tsvetan at Olimex couldn't lock onto an NTSC file either with his TV. Was that the same build Ken? Cheers Don... https://www.dontronics.com |
| Page 1 of 4 |
