Local Time 20:24 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Keyboard function key mappings
trippyben
Posted: 10:08am 01 Aug 2011
Has anyone tried to read the function key mappings as detailed in the user manual under Keyboard? "Standard IBM compatible PS2 keyboard with mini-DIN connector or a USB/mini-DIN adapter. Non ASCII keys (such as the function keys) are mapped to ASCII characters. Use a command like PRINT HEX$(VAL(INKEY$)) to check the actual mapping."
I find that the arrows, page up and down etc are mapped to their matching numeric key on the numeric keypad, but can't get a useful response for the F1 and so on keys. Does this mean those keys are not mapped by the Maxi firmware?
Ben
James_From_Canb
Posted: 10:49am 01 Aug 2011
I haven't tried - but might it be returning 2 values?
There's a table in this link called IBM scan codes which seems to say that F1 is decimal 00 followed by decimal 59.
James
trippyben
Never mind, if found the way to do it (Thanks to some code gerard wrote for sparkey)
You need to use PRINT HEX$(ASC(INKEY$)) to check the actual mapping!!
Ben
trippyben
Posted: 10:51am 01 Aug 2011
Thanks James, I'm sure that's what the keyboard is spitting out - it was more how the maximite presents the value that was required.
Jimbo
Posted: 11:01am 01 Aug 2011
The standard firmware maps the Function keys to characters with ASCII code:
F1 = 0x0e F2 = 0x0f F3 = 0x10
F4 = 0x11 F5 = 0x12 F6 = 0x13
F8 = 0x15 F9 = 0x16 F10 = 0x17
F11 = 0x18 F12 = 0x19
F7 is Defined as return 0x14, but in fact due to its SCAN code number being higher than most, is not detected correctly, and returned as F5 (So pressing F7) will always be reported as F5 and return 0x12.
This is only true for the Keyboard pluged into the mini-DIN port. Terminal programs sending characters via the USB serial will most likly expand these keys to one or more key presses before sending over the wire.
The standard firmware Doesn't support the IBM Extended Scan Codes. So keys like insert, delete, pgup, pgdn, home, end, and The standalone arrow keys, and the Numeric Keypad ENTER are not detected. They are easly added (see my attached updated keyboard.c file), however the trick is having a standard ASCII value to map them to. I chose to map mine according to http://classicteck.com/maxdev/ascii.html but there may be other standards.
Modified V2.5 Keyboard.c file to detect and map extended key scan codes.
2011-08-01_210053_Keyboard.zip
