Local Time 21:09 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Adapter PCB Idea
jman
Posted: 07:16am 01 Aug 2011
Hi all
I was wondering if any of the PCB gurus out there could come up with a PCB for
inputs outputs etc that plugs into a Maximite see the Pic.
This PCB is the same size and shape as the current Maximite PCB
with a 26 IDC connector mounted on the bottom in a DIL header if needed to make the height. Then fit a vertical mount 26 pin IDC on the Maximite so two boards can be plugged togther if the user prefers they can use 2 right angle connectors and a ribbon cable.
On the PCB four or so analog inputs set up with resistors for voltage dividers and some bat diodes for protection. ie 2 resistors and 2 diodes per analog input maybe a 3.3 zener just in case (optional). 2 or so pins setup with 1 resistor to +5v for LM35Z temperature sensor use and 2 or 4 depends on space SPDT relays all this comes to the front edge and connected via PCB monuted screw terminals
I am sure we can squeese an RTC in there to
This way we just pick the resitor values and we are ready to measure analog !
I have add a pic a shield with screw terminals
Edited by jman 2011-08-02
vasi
Posted: 02:47pm 01 Aug 2011
Hi John,
An educational board (extension, shield, whatever) with all sorts of peripherals, switches and sensors can be easily designed but, an add-on board specific to your application is up to you (or at least, you can come up with all specifications and requirements).
For an educational board, must be made a list or a sort of poll, to gather all the wishes... we may end up with two or three boards, depends on the application target...
VasiEdited by vasi 2011-08-03
Elvish name: Mablung Miriel
Beyound Arduino Lang
VK6MRG
Posted: 04:58pm 01 Aug 2011
Hi Guys,
This is a an expander that I have drawn up to have made for my farm gate opener project.
6 digital inputs,
4 digital outputs, 2 relay and 2 transistor switched.
Designed to plug onto the Maximite EV (MINI)
PS. still a work in progress.
jman
Posted: 07:13am 10 Sep 2011
So I got PCB's made for my requirements
This plugs into the Maximite (Header on Maximite is a straight type)
My PCB layout skills are not the best but the boards work ok.
Specs
Real time clock
4 relay outputs
4 Digital inputs (Transistor)
10 Analog inputs 2 of these are setup for LM35 temperature sensors.
Analog has divider just pick resistors to suit your input voltage
I have 2 spare boards with real time clock chips (8563) and crystals should anybody
want one @ around $20 NZD (This is pretty much the cost price)
Xiongmao
Posted: 08:34am 10 Sep 2011
I'll take one. just PM me your details.
jman
Posted: 10:38am 10 Sep 2011
PM sent
Ray B
Posted: 10:47am 10 Sep 2011
VK6MRG & JMAN are you offering your artwork for those who want to "roll their own" or modify. e.g. maybe with DesignSparkPCB that was discussed yesterday or Eagle that will be promoted in the next Silicon Chip.
RayB from Perth WA
jman
Posted: 11:59am 10 Sep 2011
Sure No Problem
I did this one with Pad2Pad
I will post the files here
Edit Files added
2011-09-10_222015_MaximiteAddon.zipEdited by jman 2011-09-11
Ray B
Posted: 01:35pm 10 Sep 2011
Thanks John - downloaded file but wont open in DesignSpark or in DIPTrace where when I try to import as a PCAD ASACII PCB it fails to open.
I downloaded your Pad2Pad & it opens there ok so file is not corrupt but then the SaveAs or Export choices are limited except maybe as DXF for the mechanical outline - which opened for me ok in TurboCAD. Hope these comments help others...
So much for portability between applications.
At the end of the day I know some members are producing boards for commercial purposes & yes they are well priced but then some others may want to make their own. Still battling with what PCB / Schematic program to standadize on as we all know once we start with one we don't want to convert.
RayB from Perth WA
VK6MRG
Posted: 01:44pm 10 Sep 2011
Maybe a good idea to have a poll to see what people are using to design PCB's. As I’m just starting to learn Design Spark, now would be a good time for everyone to come up with a common PCB design program for all to use.
jman
Posted: 08:33pm 10 Sep 2011
  VK6MRG said   Maybe a good idea to have a poll to see what people are using to design PCB's. As I’m just starting to learn Design Spark, now would be a good time for everyone to come up with a common PCB design program for all to use.
Yip I agree
vasi
Posted: 11:28pm 10 Sep 2011
1. I would say KiCAD for unlimited size and components and for a good PCB designer and good production files (it can be used in industrial environment). It can import (via some Eagle scripts) Eagle component libraries, boards and schematics. But you need to read a little .pdf tutorial (it come with the installer) to be ready to work with it. Not good for homemade CNC Router (maybe only for drilling)...
It is available for Win&Linux (on Mac have some problems).
2. Eagle is the most used with good libraries and footprints for Arduino shields (also a lot of Arduino shields and other open hardware projects come in Eagle format) but is limited on board size. You can use free, excellent scripts to generate g-code.
3. DipTrace for the easiest CAD program but limited on PADS (300 pads, though the design can be continued using vias instead of pads) and not limited on board size. It also generate:
[quote]DipTrace allows you to export edge polylines to DXF. The DXF files can be converted to G-code with Ace Converter (it's free).[/quote] So, very good for those having CNC Router and does not want to use other extra tools. Very good import/export features (imports Eagle schematics and components). Eagle complements it well.
If a general PCB designer is wanted, then we must see what it have to offer on:
- easy to use,
- good component library,
- component editor,
- export/import features,
- print features (for home made boards)
- g-code features (home made CNC but not for all)
- production files (for PCB fab houses).
VasiEdited by vasi 2011-09-12
Ray B
Posted: 12:07am 11 Sep 2011
Once again Vasi can be relied upon to come up with alternatives like KiCAD.
Following link compares KiCAD and Eagle http://www.bigmessowires.com/2010/05/03/eagle-vs-kicad/
RayB from Perth WA
Posted: 12:44am 11 Sep 2011
I use Protel Design explorer 99se,,
Why??? Because its the one my Company wanted for their stuff and I know how to use it...
Personally I find its interface quite awkward but it produces great results.
PS. There are some serious issues with Protel 99se and WIN 7, I have mine running in a VMware XPpro virtual Machine under WIN 7 home premium and its fine.
Link here on how to set up VMWare (free)
VMWare How-To
MikEdited by bigmik 2011-09-12
vasi
Posted: 01:16am 11 Sep 2011
Nice comments on that article.
I also can add that Eagle does not have a Pad editor on board as KiCAD have. By example, on your board you have 8 groups of drills with different diameters and your pCB fab house wants a maximum of 6 drill bits per board, with specific diameters. In Eagle, the only way to change the diameter hole of a pad is to modify the component inside the library tool. Is a pain. In KiCAD just double click on a pad and you have a dialog window with a lot of options and details. For KiCAD is already a complete Eagle component library ported. Just need to be downloaded and installed (from another site).
I recommend reading the comments from that article to see where the author did mistakes in his evaluation.
Nice article here but still, not the best one.
Bryan1
Posted: 02:09am 11 Sep 2011
I have tried using Eagle and Kicad in the past but I still prefer sprint layout to any other PCB software package. One doesn't need to have the part on file and it it is too easy to make new components and save them as a macros. The test feature is very handy for checking the circuits and any newbie trying for the first time will find it a easy package to learn. The best part it is a 10th or more less than any other pcb commercial package so home DIYer's can use it.
The export feature is also great for guys that want to route the boards on a cnc and with one button click the pcb design can be set to isolation which is purfect for cnc milling. For testing I have exported a few pcb designs and simmed them in Kcam with success everytime.
Cheers BryanEdited by Bryan1 2011-09-12
Dinosaur
Posted: 04:54am 11 Sep 2011
Hi All
I am interested in buying interface cards for the Maximite or the DuinoMite.
But I cant handle transistor inputs or outputs. They have to be opto's.
Neither do I want to spend the time designing and getting them made.
So, anyone who is contemplating such a design, I am interested.
Hervey Bay Qld.
VK6MRG
Posted: 05:01am 11 Sep 2011
Can you make up a schematic of a single channel opto isolated input circuit and I’ll see if I can add it into my Maximite interface PCB design.Edited by VK6MRG 2011-09-12
Dinosaur
Posted: 05:36am 11 Sep 2011
Hi All
Below a pic of what I use for the UBW32.
There are better options for the Output opto which is a bit slow on the PVN-012
But I have this working reliably on Machines in Geraldton & Mildura.
Hervey Bay Qld.
Ray B
Posted: 07:17am 11 Sep 2011
My concept for a flexible I/O board is to have all of the MM I/O coming out on the board to headers with a range of headers to cross connect to on-board circuit module components like Optos, Relays etc. You just then cross connect what you require. If course some I/O would be dedicated to some purposed e.g. COM1 & would connect to TTL I/O header and also Max232.
I'm a bit neurotic about blowing of the micro chip with strange voltages - hate to try to desolder & resolder it.
RayB from Perth WA
