Forum Index : Microcontroller and PC projects : huston we have lift off
sparkey
Posted: 04:29pm 30 Jul 2011
the altronics maxi is switching as per the program`s that .."i not shure who to thank ..glenn and i think jmam or anthony for the soft whare
my re modded studio series preamp is sitting on my bench switching the 5 volt relays quite fine chatteer ing away thanks to all for help ing me acomplish my mission regards sparkey
and thanks to don for the hard whare ev board ... Edited by sparkey 2011-08-01
sparkey
Posted: 05:41pm 30 Jul 2011
well i now have the switching relays running of the embeedeed board :
:i used auto run and it`s working as i had hopped it would .. so now all i have to do
is fit up the bords and let it run...cheers too all that helped me reach the point of fruition....sparkey
haiqu
Posted: 09:50pm 30 Jul 2011
Hey, well done on getting it all running!
Rob
unzip, strip, touch, finger, grep, mount, fsck, more, yes, fsck, fsck, fsck, umount, sleep
sparkey
Posted: 11:58pm 30 Jul 2011
thanks rob and its still sitting on the bench for now...chattering its guts out i`ve got three dvd players as inputs `atm....
sparkey
Posted: 08:23am 31 Jul 2011
well needless to say that my engunity has rained again the embedded is doing its job the modified preamp is switching accross the board have two dvd players hooked up for test it seem`s the goods ...well if nick can do it with a 4066 well then i can do it with my modded preamp running relays at 5 volts ,,,...cool:
it is possable to switch 10 camera inputs given that you would need an extra screen to get 10 inputs working five channells per screen...Edited by sparkey 2011-08-01
sparkey
Posted: 09:15pm 31 Jul 2011
well all seems to working thanks guy`s just wrote silchip via email on what i have done with there preamp....any audio phile would be going crazy by now but nessesity is the mother of invention....
sparkey
Posted: 09:52pm 31 Jul 2011
well if u let the magic smoke out it wont work any more...lol...
