Forum Index : Microcontroller and PC projects : Settick wont tick
ajkw
Posted: 08:38am 29 Jul 2011
I have noticed that on occasion the command Settick wont tick.
I went on to narrow things down and would be interested if it is just mine or if it is a bug as I think it is.
If you end a program with ctrl-c whilst the program happens to be at some point in the settick routine and then when you run the program again Settick won't tick, and won't work until you power down then up. This also seems to occur if there is a error in the program. I have reload firmware versions back to 2.4a before the problem ceased.
Some sample code is
10 rem a program to do something.
15 SETTICK 1,2000
20 REM doing stuff
25 a$=INKEY$
26 PRINT a$;
27 IF a$="q" THEN END
30 GOTO 20
2000 PRINT "x";
2010 IRETURN
(This give something like a reverse matrix effect!)
So, if you end this program by pressing q and then run it again it works fine but if you end it with control-c then run it again the routine at 2000 is not run, ie No tick.
If you change line 15 to
15 settick 1000,2000
which gives plenty of time to press control-c whilst not in the settick routine then you can end with control-c and then run again ok.
Mine or a bug??
Cheers,
Anthony.
BobDevries
Posted: 09:22am 29 Jul 2011
Hello Anthony,
I have just tried your example using your instructions regarding termination with CTRL-C, and can confirm that mine behaves the same as yours.
Bob Devries
Dalby, QLD, Australia
seco61
Posted: 12:30pm 29 Jul 2011
Hi All.
I have had a quick look at the code and understand why this is happening. The bug will also affect ANY interrupt routine - ie they will never be invoked. This currently means that the pin change interrupt and the I2C interrupt routines as well as the settick will not be invoked if CNTL-C is invoked while the interpreter is executing an interrupt routine.
The fix is simple, and a version of the 2.5 firmware with the fix is here: Maximite.hex
However, I will send the source to Geoff to verify that that is the way he wishes to fix it. Of course, as he is now enjoying a trip along the Gibb River road (and I wish I was with him!) it may take a little while for the official fix.
Gerard (vk3cg/vk3grs)Edited by seco61 2011-07-30
donmck
Posted: 12:38pm 29 Jul 2011
  seco61 said   Hi All.
Great work Gerard, I know the work you are doing will assist Geoff greatly when he does get back on the air.
I wish I was with him too, but we wouldn't be seeing too many sunsets, and the wife's club would hate us I'm sure.
Cheers Don...
https://www.dontronics.com
seco61
Posted: 09:48pm 29 Jul 2011
  donmck said  Great work Gerard, I know the work you are doing will assist Geoff greatly when he does get back on the air.
Cheers Don...
Hi Don.
My wife would only be upset if she was not travelling with us! We last travelled that part of Australia about 9 years ago and it is stunningly beautiful - we are looking forward to revisiting when the kids have finished secondary school (another 2 years....).
Gerard (vk3cg/vk3grs)Edited by seco61 2011-07-31
