Forum Index : Microcontroller and PC projects : New Maximite MMBasic Version - V2.5
Posted: 07:20am 26 Jul 2011
Hi everyone,
There is a new version (2.5) of the Maximite firmware (including MMBasic) available for download at http://geoffg.net/maximite.html#Downloads
This is essentially the same as the test version 2.4C with a few extra bugs fixed. It contains Gerard's I2C routines, the EDIT command and all the other stuff.
The “Maximite User Manual” has also been upgraded to V2.5 to include the new features.
Bill.b
Posted: 10:57am 26 Jul 2011
geoff
just loaded v2.5 there appears to be some video jitter.
reloaded v2.4A video is normal no jitter
Bill Brown
captainbill
Posted: 10:59am 26 Jul 2011
Howdy Geoff
Thanks for the new MMB software. I know how busy you must be on your great adventure this summer. Last summer I pulled a camper from Kansas City 13,000 miles round trip in 12 weeks up the Alaska Highway as far as the Arctic Circle and all over Alaska. I couldn't have imagined finding time to write code.
We appreciate you taking some time to update your wonderful MMB. The hardware and software are amazing.
Old school. Still interested. Head in the clouds.
James_From_Canb
Posted: 11:43am 26 Jul 2011
That's a good point. I'll bet your camping trip was to relax after designing the Maximite. It doesn't sound too relaxing so far.
I have this picture in my head of you concentrating on a laptop while there's a brilliant sunset happening behind you.
Ignore the upgrade cycle for a while. Have a good break.
sparkey
Posted: 02:46pm 26 Jul 2011
hi geoff i have 2pont 5 running on my altonics the maxi is prolly from the first run of kits i got it from rohan
Posted: 03:13am 27 Jul 2011
  Bill.b said   geoff
Bill Brown
Has anyone else seen this jitter?
I did not see any so I cannot figure out what it could be.
Also, there was an error in the documentation (MM.I2C was substituted for MM.ERRNO on page 6). I corrected it quickly so if you find that error in your user manual please download again.
Finally, I will be out of range again for up to 2 weeks (the Gibb River Road). If you discover a serious issue with 2.5 it would be best to revert to 2.4C.
Posted: 03:38am 27 Jul 2011
Hate to say it but I notice some video jitter too with 2.5.
Its only mild and would probably be un-noticible on most monitors.
donmck
Posted: 03:43am 27 Jul 2011
  Gizmo said   Hate to say it but I notice some video jitter too with 2.5.
I just updated, and couldn't see it on my old LCD monitor.
I did find that all USB ports aren't equal. The port I tried had enough power to run the VGA and Keyboard, but not to download and verify the Version update. Had to try a direct port before I could verify OK.
Cheers Don...
https://www.dontronics.com
seco61
Posted: 03:54am 27 Jul 2011
Hi All.
When you are seeing "video jitter", could you please define the jitter you are seeing.
Is it a vertical jitter with the whole screen display moving up and down slightly, or just some lines of pixels moving up and down?
Or is it horizontal jitter with the whole display moving left and right, or some lines of pixels moving left and right?
Or something else?
Is it occuring in VGA mode or composite mode or both?
This information would help with diagnosing the issue.
regards
Gerard (vk3cg/vk3grs)Edited by seco61 2011-07-28
Bill.b
Posted: 04:26am 27 Jul 2011
It would apear to be vertical movement of the on screen
text on the VGA output. I am using a LCD VGA monitor
Posted: 06:22am 27 Jul 2011
It hard to describe. On a verticle line, say the letter I, I would see whats could be described as random static or noise down the right hand side of the line, no more than 1 pixel wide. I would say its very minor compared to other video problems we have see in pervious versions.
BobDevries
Posted: 08:25am 27 Jul 2011
Hi all,
I have just updated my Maximite to V2.5.
I see no more flicker or glitches than before, and only some when I'm running tightly looped code such as in my clock, and also the digital clock presented here recently.
I removed the glitching in the digital clock programme by adding a line:
85 PAUSE 500
I used this technique in my Analog clock also.
BTW, I changed line 2920 as follows:
2920 LINE (DigitX + 20,DigitY + 25)-(DigitX + 25, DigitY + 45),1,bf 'segment C
Which lengthens the tail of the digit 9 to make it more like the other numerals.
Bob Devries
Dalby, QLD, Australia
Ray B
Posted: 08:57am 27 Jul 2011
  captainbill said   Howdy Geoff
Just to add the international flavour I'm currently posting from Bali. Was going to bring my MM with me and post a photo of a MM with a balinese dancer or maybe pulled up at the bar having a bintang or 2 or something as corny as those photos you see of Gnones or Teddy Bears that people drag around the world but in indonesia the customs would want to confiscate it....
Geoff good to see your back home and the product is developing..... Now if only we had serial we could get some basic GUI code running.
Selmat Tinggal.
RayB from Perth WA
trippyben
Posted: 11:18am 27 Jul 2011
V2.5 looks OK on my old IBM LCD - no sign of any video jitter that wasn't there before.
Ben
donmck
Posted: 02:16pm 27 Jul 2011
Max visits the Eiffel Tower. Max does Madrid. I can imagine.
BTW:
This weekend, complements of Chuck, Max's affair in Detroit.
A Maximite SM1 prototype is being shown in the northern hemisphere for the first time at http://makerfaire.com/detroit/2011/ in Detroit at the end of this month, at Chuck Hellebuyck's stand.
Cheers Don...
Gadget
Posted: 02:43pm 27 Jul 2011
I just noticed an anomaly with this (and earlier) version of the firmware.
the date handling routine when the user enters a 2 digit year ie 27-07-11 the date, it is then reported as 27-07-0011.
i found this when running the analog clock program and it had the incorrect day of the week.
Terry
donmck
Posted: 03:16pm 27 Jul 2011
  Gadget said   Hi,
Terry
AHA!
The Y2K bug has finally hit us.
Cheers Don...
seco61
Posted: 08:54pm 27 Jul 2011
  Gadget said   Hi,
Terry
Hi Terry.
Until Geoff has an official fix, here is a new version of Maximite.hex that has the Date$ command altered to accept a 2 digit year and place it in the 2000's. The code is otherwise identical to the v2.5 release.
The altered Date$ command code (cmd_date in misc.c):
// this is invoked as a command (ie, date$ = "6/7/2010")
// search through the line looking for the equals sign and step over it,
// evaluate the rest of the command, split it up and save in the system counters
void cmd_date(void) {
char *arg;
int d, m, y;
while(*cmdline && tokenfunction(*cmdline) != op_equal) cmdline++;
if(!*cmdline) error("Invalid syntax");
++cmdline;
arg = getstring(cmdline);
getargs(&arg, 5, "-/"); // this is a macro and must be the first executable stmt in a block
if(argc != 5) error("Invalid syntax");
d = atoi(argv[0]);
m = atoi(argv[2]);
y = atoi(argv[4]);
if(d < 1 || d > 31 || m < 1 || m > 12 || y < 0 || (y > 99 && y < 1000)) error("Invalid date");
if (y < 100) y += 2000;
day = d;
month = m;
year = y;
Ensure you make the browser window wide enough to show the code else the code gets split in a weird place...
regards
Gerard (vk3cg/vk3grs)Edited by seco61 2011-07-29
Gadget
Posted: 11:32am 28 Jul 2011
  seco61 said
  Gadget said   Hi,
Terry
Hi Terry.
char *arg;
int d, m, y;
++cmdline;
d = atoi(argv[0]);
m = atoi(argv[2]);
y = atoi(argv[4]);
day = d;
month = m;
year = y;
regards
Gerard, I had done something similar myself.
told Geoff of the problem, and sent him my other mods to the firmware for review
(programmable characters)
Terry
wizard
Posted: 05:34pm 28 Jul 2011
Hi all,
Does anyone have Maximite compiling under Linux?
My toolchain is totally open source, even down to jtag programming
the pic32 via xc3sprog (modified).
warm regards,
Wiz
