Local Time 20:25 25 Aug 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micro SD Card
elproducts
Posted: 04:20pm 04 Jul 2011
Would a micro SD card work the same as the SD card on Maximite if I used the smaller socket?
I'm breadboarding a Maximite and found a microSD card socket board that plugs into the breadboard.
I wasn't sure if the interface was different.
www.elproducts.com
donmck
Posted: 08:08pm 04 Jul 2011
  elproducts said   Would a micro SD card work the same as the SD card on Maximite if I used the smaller socket?
Hi Chuck, details at:
http://www.themaximitecomputer.com/maximite-ev-smd/
We have this above Maximite EV design about to go into first prototype, in fact it may be getting populated now.
And we have another with very different features, in the design stage. Features that I know you will like.
Cheers Don...
https://www.dontronics.com
captainbill
Posted: 08:33pm 04 Jul 2011
Howdy
Regarding breadboarding a MM, how did you attach the SMD PIC32 to the board? Was it soldered to a chip carrier? If so, how did you accomplish it?
I would like to do a breadboard MM but I don't want to attempt the SMD soldering.
Which brings me to my next point. Will one of the hardware vendor guys be providing a PIC32 soldered to a chip carrier? At a good price? Maybe even the 100 pin version? ;-)
Inquiring minds want to know.
Old school. Still interested. Head in the clouds.
aargee
Posted: 10:31pm 04 Jul 2011
Bill,
Have a look at the UBW32 and have a look here as to what I did with it..
- Rob.
stuarts
Posted: 11:40am 07 Jul 2011
Captainbill, have a look at geoffg.net and have a look at his article on SMD soldering. It's not as scary as it looks. I've soldered 2 PIC32s to Maximite boards and both are up and running. I didn't like the idea of it, but now that I have done the 2 and soldered a couple of I2C chips to boards I feel a whole lot better about it.
I did end up buying a microscope from the company that Geoff mentions on his page.
It makes the job much easier.
Stuart
Time is nature's way of keeping everything from happening all at once.
donmck
Posted: 04:46pm 07 Jul 2011
  captainbill said   Howdy
Cap'n Bill, have a look here for full info:
http://www.dontronics-shop.com/usb-32-bit-whacker-pic32mx795 -development-board.html
BTW. I don't expect you to buy from me, as my price on this item is higher than SparkFuns, as I buy from them anyway, And as you are state side, they will be quicker.
We have a lot more in the pipeline, and I am flat out working on designs right now, 48 hour Sundays, all that sort of thing. So much for my retirement. :-)
Cheers Don...
