Local Time 18:39 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : programing help needed
sparkey
Posted: 02:21pm 29 Jun 2011
i have at present three programes that i need to run at the same time given this fact they are
:text disp voltmeter
: text dispay frequency counter : frquency generat..no disp on this one
the volt meter prog is about 15 lines
the frequency generator is about 12 lines
and the counter is 6 lines ....
given thae fact that i can get each of these programes to run singleary ..i guess i need to compile them to geather and only run one programme
:the freq gen needs to run constant at first
then either the volt meter and the counter in the latter but i need to display Hz and volts ...i am really brand new at programming ..but then jumping in the deep end you learn to swim ...thanks to any who reply...
thanks too gizzmo and the j man for supplying my starting programs.....thats who
gave them too me getting a new printer today so i can print the three programs and nut it out...regards .....Edited by sparkey 2011-07-01
sparkey
Posted: 05:45pm 29 Jun 2011
ok i have joined the freq generator and freq counter together ..all done on the maxi .
..getting there now the hard part adding the voltmeter ...regars sparkey....
:::NESESSITY THE MOTHER OF INVENTION:::
:: ok i think i got it i just learnt how to use "locate" very interesting....Edited by sparkey 2011-07-01
sparkey
Posted: 06:39pm 29 Jun 2011
problem solved and i did it all on the maxi thanks to those who may have been thinking of me friday i get my new cro probe so hope fully its generating some sort of square wave but only time will tell....
:::i crack my self up sometimes::: thanks all ...sparkey....
sparkey
Posted: 07:25pm 29 Jun 2011
ok well i got the screen to display volts and freq but the freq counter wont re fresh or count ...i guess i will have too do some more thinking but i will get there eventully ...oh the counter is off of glenns maxi page its a 5 line program ;;;firs ex is the volt meter then the counter i dont know what i`ve done wrong the counter wont count and i dont know how to get this program up on the forum so ...
