Local Time 18:38 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : freq gen set pin
sparkey
Posted: 02:41pm 28 Jun 2011
ok if any body can help me with this
:iwant to make a digital output pin switch from high to low :
:also i would like to be able to control the time it is high and low ..states
: i would also like to be able to do this in real time but if thats just a hell of a lot of programme the latter will be fine i can just go into the program and set the variable manually....thanks to all whom reply
BobDevries
Posted: 09:25pm 28 Jun 2011
try this:
10 setpin 10,8: rem set pin 10 for digital output
20 do
30 pin(10)= 1:rem set pin 10 to logic high
30 pause 500: rem pause for 500 mSec
40 pin(10) = 0: rem set pin 10 to logic low
50 pause 500
60 loop
70 end
In a real life situation you can use the TIMER to see how much time has elapsed, and then you can do other code while waiting for it to get to the value you need. Remember, the TIMER counts UP in mSec. You can set it to 0, and then check periodically to see if it has the value you need.
Hope that helps,
Bob Devries
Dalby, QLD, Australia
BobDevries
Posted: 09:43pm 28 Jun 2011
By the way....
NEVER use the TIMER function to get a specific value if you're executing other code while waiting for it. Chances are that you'll miss your target value.
10 SETPIN 10,8
20 TIMER = 0: PIN(10) = 1
30 DO WHILE TIMER < 500
40 GOSUB 100
50 LOOP
60 TIMER = 0: PIN(10) = 0
70 DO WHILE TIMER < 500
80 GOSUB 120
90 LOOP
60 END
100 REM subroutine to do something while you're waiting
110 RETURN
120 REM another subroutine
130 RETURN
Bob Devries
Posted: 10:17pm 28 Jun 2011
Ideally you would use some sort of PWM output, where you set the on time, off time and it will run in the background until you make a change to it. At this time the Maximite doens't support a PWM output, so we need to do it with software.
I havn't tried it yet but you might be able to use the SETTICK command. Its a interrupt, meaning it will interrupt your normal program at a certain time.
I havn't tested this, its probably broken. The two timer routines at 1000 and 2000 should flip flop between eachother.
5 SETPIN 10,8 'Set as output
10 SETTICK 100,1000 'Start timer in 100ms
20 ' Normal program, do stuff
30 PRINT RND()
40 GOTO 30
1000 'On Time, 10ms
1010 SETTICK 10,2000
1020 PIN(10)=1
1030 IRETURN
2000 'Off Time, 100ms
2010 SETTICK 100,1000
2020 PIN(10)=0
2030 IRETURN
BobDevries
Posted: 10:41pm 28 Jun 2011
Hey Glenn,
excellent example. I'm learning from this.
I had used the SETTICK command before, I just didn't think of it in this instance.
And yes, it works fine.
Bob Devries
sparkey
Posted: 08:28am 29 Jun 2011
30 PRINT RND()
40 GOTO 30
are these three lines nesscary it loks to me like a ramdom n0 gen loop and thows a heap of numbers down the screen ....thanks ....
