Local Time 18:26 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : setpin analog volts prob
sparkey
Posted: 03:32am 24 Jun 2011
when i use setpin "setpin 1,1"..then print that pin i am getting voltages from point 8 of a volt to 2point 5 volts nothing connected to i/o at all should this be so erratic ...thank you....
BobDevries
Posted: 04:28am 24 Jun 2011
The inputs tend to float a bit if there is no termination. Try putting a 10K resistor to ground, and see if it fixes this.
Bob Devries
Dalby, QLD, Australia
