Local Time 18:25 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Help with MMBasic
Talbit
Posted: 03:11am 22 Jun 2011
Geoff designed a simple 2 x 16 lcd display and runs it with a bit of code lcd.bas. In line 20 he has LCD_Line1$ = " HELLO WORLD " and line 30 is similar.
It displays it on the lcd nicely.
I'm designing a clock (don't ask) and I have hh$ equal to hours, mm$ equal to minutes and ss$ equal to seconds. I don't want to change Geoff's LCD code.
How can I plug my hh$ mm$ ss$ into line 20 so that it will eventually display
hh:mm:ss in the first line.
Thanks for your help
Talbit
Talbit
captainbill
Posted: 03:27am 22 Jun 2011
Howdy
Try this.
LCD_Line1$=hh$+":"+mm$+":"+ss$
You can add strings together.
Hope this helps.
Old school. Still interested. Head in the clouds.
Talbit
Posted: 04:19am 22 Jun 2011
Thanks Captainbill!
That worked beautifully! I wasn't aware of adding the +
Now I'm going to really push the friendship. When I reach single digits I need to add leading zeros on the display. Can this be implimented in this setup?
I can send all of my code if you want it.
Talbit
Talbit
captainbill
Posted: 05:23am 22 Jun 2011
Howdy
Try this.
if len(hh$)=1 then hh$="0"+hh$
Talbit
Posted: 05:51am 22 Jun 2011
Spot on. It works!
Thanks for your help.
I just need Geoff to impliment his serial in so that I can use a gps NMEA string and the PPS to run my super accurate clock.
Talbit
Talbit
