Local Time 18:38 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DIR command/Function wish?
thetinkerer
Posted: 08:55am 20 Jun 2011
It was a long time ago but the DIR command which returned a string.
You could use it like this:
result$= DIR("*.BAS")
result$=DIR()
'do something
while len(result$)>0
Essentially you give the DIR a file mask the first go and then call Dir till there are no more entries.
In fact, the MM "files" command internally works in this fashion.
I was wondering if people would find this handy to have a DIR function in MMbasic that returned a string as described? This would allow you to have programs list files and keep track of them as well as do things like
FileExists = (Len(dir$("filen.ame"))>0) etc.
thetinkerer
Posted: 09:12am 20 Jun 2011
Just one extra bit.
I know that This function is actually from VB and not from Qbasic but I just thought it may be handy and should be straight for to implement.
