Local Time 18:25 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : sq wave gen prog need help
sparkey
Posted: 01:58pm 15 Jun 2011
ok if any body can help here..need either a small program to set one of the digital pins on and of as well as being to adust on time and off time..i`m guessing i need to use one of the digital pins on the headder i ;;;;;
or even steer me in the right direction "i am not really fimiliur with the hows and why`s of what the program lines are /or strings /and so on but once i know what i am looking at i will decipher from the mm..manual.....
thanks to all who reply regards sparkey
thetinkerer
Posted: 07:51pm 15 Jun 2011
Hello Sparky,
you will need to
- configure a pin for output - SETPIN command
- set the pin high - PIN Command
- have a "on" delay
- set the pin low
- have another delay ("off" delay)
you could perhaps use the Setick to create a timed interrupt(equal on/off time)
May I suggest you sit down and read the manual from cover to cover so that you can familiarise yourself with all the commands.
sparkey
Posted: 08:12pm 15 Jun 2011
thank you regards sparkey i am no programmer expert but thanks for at least showing me a direction..and yes i will read the manual but its like if you dont have a start point then reading becomes teadious and might not be absorbed...
