Forum Index : Microcontroller and PC projects : maxi mite
| sparkey Senior Member Joined: 15/06/2011 Location: AustraliaPosts: 819 |
there was a post on geoffs page that showe somebodys mods inclding a simple programme for a freq counter cant seem to find the page ..also showed heat sink on the 5 volt reg and a speaker connection any help pls thank you.sparkey.. technicians do it with least resistance |
mac46![]() Guru Joined: 07/02/2008 Location: United StatesPosts: 412 |
Sparky, Page 3 of Gizmo's post "the Maximite", is I believe what you'r looking for. By the way, Welcome to the forum. ...Mac46 I'm just a farmer |
i cannot seem to find the counter programme may be i am incorrect as to where it was posted it only had abot five lines and it was good for 200Hz technicians do it with least resistance |
i found the prog thanks all regards sparkey.. technicians do it with least resistance |
That program was not tested, I wrote it before I had a Maximite to play around with. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
It does, just tried it. The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
